Question about Skilsaw 5400 Circular Saws
Where is blade lock on skilsaw 5400
I am changing blades on my Skilsaw 5400 and can not find a blade lock to hold the blade or motor to loosen the nut
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Posted on Jun 27, 2009
hondo73162
  • 132 Answers
SOURCE: Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Posted on Nov 09, 2009
  • 15 Answers
SOURCE: How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Posted on Jun 08, 2010
SOURCE: Where is the blade lock button on a skilsaw 5150 2
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Posted on Nov 12, 2010
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Change blade
What model of saw are you using? BE SURE TO DISCONNECT THE POWER CORD. There is usually a brake that you push in to lock the motor, it is usually located between the upper blade guard and the handle, on the motor. It should be spring loaded, push it in and hold it in the loosen the nut on the blade, counter clockwise CCW, righty tighty, lefty loosey.
If you still cannot find a brake, put a screwdriver into the curved part of a tooth behind the carbide tip and 90 degrees to the blade near the front of the lower blade guard. It should be below the main shoe (plate that the saw sits on while cutting). When you turn the nut CCW, the screwdriver will lock the blade against the main show and the blade nut may then be loosened and the motor shaft should not spin.
If all this fails, read the instructions and look there for a brake lock.
Nov 29, 2014 | Saws
How do I change the blade
Unplug the saw. I repeat, unplug the saw and then lift the guard all the way up. Set the teeth of the blade in a wood board to keep it from moving and then loosen the blade. If that doesn't work, go to a bike repair shop and ask to borrow/rent a thin wrench that fits behind the blade. Probably a 3/4 or 7/8" wrench. Use that to hold the blade secure then loosen the blade nut.
Sep 13, 2014 | Saws
Witch way to turn the blade bolt on a 10" table saw
I'd be surprised if it were anything but a normal, right handed thread.
So, put on some leather gloves, block the blade from turning with a piece of scrap lumber. Use the appropriate size blade wrench and, I assume you're removing the blade, pull the wrench toward you to loosen it. Always remember, lefty loosy, righty tighty and you'll never wonder which way to turn it again. Obviously if this method tightens the nut rather than loosening it, it's a left handed thread and needs to go the opposite direction. Should loosen/tighten rather easily, so don't force it one way or the other.
Aug 31, 2014 | Skil 10" 60T Skilsaw Circular Saw Blade -...
Shaft lock will not hold cant change blade
Generally yes. Just put a screwdriver or bar of metal into the teeth of the blade and crank the nut. In the old days that was how we did it all the time.
A vicegrip can be clamped on the blade if you want to protect the teeth.
May 25, 2014 | Craftsman 10" Table Saw
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
Jun 07, 2010 | Skil Saws
Blade change skilsaw 5150
The locking button on this saw is designed for safety. If you are attempting to change the blade it should NOT be plugged in. It sounds as if someone has pushed the lock button while the motor was running and sheared it off.
The only tool that is required to change the blade is the supplied wrench or an equivalent box end. If you cannot make the repair yourself for have the equipment repaired you can take a pair of vise grips. (Use cardboard to prevent warping or gouging the blade) and clamp the edge of the blade below the teeth. The vise grips will stop at the front of the saw as it is too large to pass by the guard allowing you to loosen the nut. Clamp the new blade in the same way only the back of the saw will be used to tighten.
I highly recommend that you either repair yourself or have the tool repaired by a professional.
Parts schematics are all over the net for this tool, here is an example:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/skil/5150
As you can see most of the mechanical parts are only a few dollars and it could save you from serious injury during operation.
Feb 13, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Skilsaw 5400 Circular Saws Logo
335 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
