Question about Riso RZ390 Duplicator
Driver riso rz 390 ui duplicador - Riso RZ390 Duplicator
4 Suggested Answers
  • 55 Answers
SOURCE: necesito bajar el driver de la riso rz 390 ui
Please follow this link to download the driver from the original source - Riso:
http://www.risographie.de/riso/index.jsp?page=187&lang=1
Please notice that this site is in German language, but do not hesitate you will find what you need!
Posted on May 01, 2011
ZJLimited
  • 17970 Answers
SOURCE: Tengo una duplicador RISO 390,
Error H01: Ink color setting error Cannot get consumables info input values required. Enter the required parameter value. (1: black / 2: color)
* Error de ajuste de color de la tinta no se puede obtener informaci?n de entrada consumibles valores requeridos. Introduzca el valor del par?metro requerido. (1: negro / 2: color)
Posted on May 11, 2011
  • 55 Answers
SOURCE: the riso rz 390 ui
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Posted on Apr 27, 2011
Why do not feed more than one or two pages
Check if there is dust or if the output is holding paper sheets to pass. It may be that some of the gear output paper is loosely screw on the shaft causing the problem. Also check the registration sensor inside the machine and clean it. I hope I helped you.
Jul 08, 2014 | Riso RZ390 Duplicator
How do you enter user codes on a riso RZ 390
by pressing print position keys Plus 15 & minus 15 at a time with one hand and by using other hand machine power on, and release both keys u will in test mode
Jun 19, 2014 | Riso RZ390 Duplicator
Riso rz 390
There should be a built in head cleaner. I think you can access it through the control panel, then device and printers. right click on the printer with the issue, scroll down to printer properties. there should be a box that says "print test page" when the test page prints it should ask you if it is ok, this is where the clean head should be.
Jan 18, 2014 | Office Equipment & Supplies
Necesito bajar el driver de la riso rz 390 ui gratis
Apr 21, 2011 | Riso RZ390 Duplicator
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
The riso rz 390 ui does not print the scans complete
Feb 03, 2011 | Riso RZ390 Duplicator
I have a Riso 390 ui RZ i did an electric chock accidentaly on my building the duplicator was working, but after the chock it smelled like smoke inside the machine now it doens't star what part do I...
You have a small circuit board. That is after the power source.Unplug and open the duplo.The circuit board you can order from Riso and have installed by an authourised technition.Good luck
Aug 13, 2010 | Riso RZ390 Duplicator
We own a Risco RZ 390 UI, and are not able to use it, due to a code that has appeared on the screen: Code P-19 What does this code mean?
This a proble with the Thermal print head. You will need to call service to repair. When you call press the point key to get the rest of the code.
Jun 16, 2010 | Riso RZ390 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Sep 05, 2008 | Riso RZ220 Duplicator
286 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
