Question about Coleman Quickpump
Won't turn on, gets hot
Put new batteries in, will not work. Unit and batteries got very hot. What could the problem be?
On my Air conditioner, there are no buttons for me to change controls on it, as well as the remote is not working. Could you possibly help me resolve this ? I put brand new batteries in it.
The remote is the only controller. Try turning off the power to the system at the breaker or o.d. disconnect, wait about 10 mins(at least 5) and then turn power back on. This should reset the system and if it has the controller locked out, should reset it also. If not, the remote may be damaged. Or I.d. unit sensing capabilities are damaged. Make sure the battery terminals in the remote are not corroded or broken and the batteries are new/hot. If the indoor unit has had water leak issues it may have damaged the sensor inside the air handler. I'm not sure what unit you have, window unit or mini split
Jun 23, 2015 | Heating & Cooling
Have nothing working no lights battery aint getting power Good wires ,good alternator,battery lights used to turn on
Sometimes there is a fusible link in the hot lead to the battery. Check shop manual to see if there is one. Otherwise, look for bulge somewhere close to the hot battery connector. Look for fusible links elsewhere if you cant find one near battery.
Feb 04, 2015 | Cars & Trucks
Hot wheels sky jump track does not operate
TRY TO BUY A NEW ONE ,RETURN THE OLD ONE ,
-ANNA LEIGH MASON
Mar 21, 2013 | Mattel Hot Wheels Sky Jump Track Set
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
Hot from the battery is no longer working solution please
The battery is faulty and you need to replace it with a new one.
Sep 26, 2012 | Nokia 5250 Cell Phone
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
Motor turns over won't start. Cleaned terminals, put in new battery, still won't start. Removed gas cap to vent air on hot day, still won't start. Lights all come on, all electrics appear to...
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 1997 Chevrolet Blazer
I HAVE A 1992 NISSAN PATHFINDER AND I HAD A MECHANIC PUT IN A NEW STARTER AND IT STILL WON'T START WHEN IT GETS HOT. I HAVE TO WAIT TILL IT COOLS DOWN THEN SOMETIMES HAVE TO TAP THE STARTER. THE...
If he installed a new or remanufatured starter, I would suspect a weak battery possibly. If he installed a used starter, I would say the starter is bad. A hot engine is harder to crank than a cold engine and if the starter is marginal it will act the way you described. Try boosting your vehicle the next time it's hot, or get your battery load tested by a reputable shop that doesn't sell batteries. I have had experience with remanufactured starters that were no better than the unit I removed from the vehicle. Have him get a second reman and see if that doesn't solve the problem.
Aug 17, 2011 | 1992 Nissan Pathfinder
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Jun 17, 2011 | 1999 Ford Windstar
Coleman Quickpump Logo
Top Coleman Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Coleman Cycling Expert? Answer questions, earn points and help others
