How to fix Toshiba Rear Projection Television
1991 Toshiba CRT- Rear Projection TV Model #TP55902 Screen flickers a great amount at top, bottom, and both sides. Will go back to normal, after the inside is heated up with a hair-dryer, but only for a few minutes.
    Champion:
  • 247 Answers
Check colour wheel needs replacement bearing are worn out
Posted on Jul 14, 2013
hardrocko
  • 1476 Answers
SOURCE: TV Flickers red lines across tv screen
Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
Posted on Jul 12, 2006
  • 1153 Answers
SOURCE: half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Posted on Sep 14, 2007
  • 1694 Answers
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Posted on Apr 25, 2008
SOURCE: blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Posted on Sep 06, 2008
welcomejee
  • 10594 Answers
SOURCE: REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Posted on Jan 26, 2009
My Toshiba 51 inch projection tv has red squares on screen
The model indicated is a projection set and the question is does it look 3d looking etc or something else?
See attached photos of typical convergence problem which MAY be what you have.
SD TECH
May 02, 2010 | Toshiba 51H83 51" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
When I turn the tv on it flickers and there is a
Cold solder joint on the board. Time to call a TV tech..
N Sabre
Nov 08, 2009 | Toshiba 50H82 50" Rear Projection...
When i turn on my tv it starts with a very distorted picture
got the same TV with the same exact problem....what is it??? if u crack it tell me and i'll do the same...
Oct 07, 2009 | Toshiba 50HDX82 50" Rear Projection...
Green flickering and not lined up with red and blue
well I am not tom but your tv is having a convergence problem only a technician may be able to replace the bad ic inside the set
Aug 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Jun 29, 2006 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
