Hoover hnt 6614 d
MANUAL
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: HNT 2135 Top Load Washer drum locked and can't
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • 6277 Answers
SOURCE: I have rented a furnished flat and i dont know how
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 14, 2011
I have rented a furnished flat and i dont know how to work with Hoover Nextra HNT 2135 Top Load Washer
Manual
John C.
Oct 14, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Wher can I get the instruction manuel as I have lost mine. Thank you
Manual
John C.
Aug 19, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Looking for the manual but no one has uploaded one for this product
You could try
http://www.mauritron2.com/service_manuals.html
or
http://www.mauritron2.com/operating_guides.html
We've used them in the past and found them very good.
Also if it is not listed then ask via the link
Aug 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
Feb 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hello, my Hoover 700LB toploader won,t spin or agitate, the pump is working, but the motor is not working at all,
Hi just read your posting.Now the problem could be your motor or motor module.Have you got or can borrow an electrical test meter to test the motor and wiring? Please reply back and and I can guide you the finding of the fault and the repair.Also I will look at my manual to see if you can test for the fault without a test meter.Looking forward to your reply.
Aug 24, 2010 | Hoover Nextra HNT 2135 Top Load Washer
Drum very noisey
same prob with mine. the pulley is cracked
Nov 13, 2008 | Hoover Nextra HNT 2135 Top Load Washer
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
