Question about Motorola Mobility A1200
Waiting for database problems
When i select messageing it brings up a window saying waiting for database. once it finally loads it does it all over agian. so no incoming messaging and no out going messaging. also my phonebook is not load so i guess that is waiting for database also. i have no clue what to do to fix this. i have inserted a different sim and it does it with it as well... hope to here so help
  • 4 more comments
  • Anonymous Aug 22, 2008
    A1200 Progressive Problem - now dead A1200 General Chat. ... me an error message when I tried to open my phonebook or text messages saying "Waiting for DB" any fixes
  • mickyfun06 Sep 04, 2008
    My file manager, contacts and message does not respond. it either gives a 'waiting for database' message or no response at all. plz wat do i do.
  • julianlxdxs Dec 29, 2008
    when i select messageing it brings up a window saying waiting for database. once it finally loads it does it all over agian. so no incoming messaging and no out going messaging. also my phonebook is not load so i guess that is waiting for database also. i have no clue what to do to fix this. i have inserted a different sim and it does it with it as well... hope to here so help
  • Anonymous Apr 06, 2009
    Thanks, it works like the man said, taking out the micro SD, couse I'd try first and it didn't works with the card inside, must be for the AMVO, or another kind of infection....
  • myall_3131 May 02, 2009
    thank you so much.....soooooo.....muuuuuchh....
    it's work and help me so,
    God Bless u..
  • wchoon1 May 04, 2009
    whenever i select message it says waiting for database', after it completes that it starts all over again,i cannot open my contacts to view or add new contacts...please help
Y se olvide el codigo de seguridad de mi motorolla a 1200 q otra solucion tengo :S
Posted on Sep 08, 2009
I was having the same problem after I accidentally pull out the battery with the power on. After I did the reset and clear,everything was back to normal. Thank you very much for posting the solution.
Posted on Sep 14, 2008
Thx it`s Works
Gracias me funciono :)
Posted on May 20, 2008
I have done a master clear and a master reset with taking out my micro SD card. And it solved the problem good luck
Posted on Sep 23, 2007
    New Friend:
Moto A1200 message stating waiting for database can not access sms
Posted on Feb 24, 2010
6ya staff
SOURCE:
My emachine computer has a black message screen,it will not bring up my windows for any reason what can I do to fix the problem and get online
If it's a black screen with no messages just hold down the power button on your PC, wait for it to turn off and let go. Wait a bit and turn it back on and hit the F8 key and select to start up Windows using SAFE MODE. It should work than.
Oct 02, 2013 | E-Machines eMachines Desktop PC
Flash Loader Utility incompatible
If FLU is referring to USB drives, then try adjusting the boot menu order in BIOS and make the hard drive 1st boot.
Feb 25, 2013 | Sony VAIO VGN-CR220E/P Notebook
A pop-up window keeps coming <KAV 201- Notification license> asking me to update. when I click on update, My update centre says STOP Update 0% instead of asking me to START Update. It also says the...
You need to wait for an update process. If this is the first time you have updating, its became too long to wait since update database is too big. Also depends on your internet connection speed..
License notification means you need to activate the software, fill it with the activation code you have when you purchased then select activate.
Jul 31, 2011 | Computers & Internet
Have lost four preset channels on my Technika DAB 109CR digital clock radio and lost manual so have nothing to consult to get back these stations. Everything live but showing only one station constantly
Finally sussed out how to (re)set presets, overall you need a little patience:
Probably best to press Autotune before we set off and let it do its thing.
Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play.
Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again)
Use dial to find station you want AND LEAVE to tune in.
Press AND hold presets down until number flashes.
Press jog/select once briefly (normally).
Press presets once briefly...it should now say "Saved"
Leave to save for a few seconds.
Voila!
You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
Feb 20, 2011 | Audio Players & Recorders
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can't delete email from blackberry phone
  1. the Backup and Restore window, click Advanced.
  2. In the Device Databases list, select the Messages database, then click Clear.
  3. A warning message appears. Click OK to continue. The database is deleted from the BlackBerry smartphone.
  4. Click Refresh to update the messages database on the BlackBerry smartphone.
  5. From the File menu, click Open.
  6. Go to the location where the BlackBerry smartphone backup file is saved, select the backup file, and click Open.
  7. In the Computer databases list, select Messages. Click the arrow pointing to the Device Databases list.
  8. A warning message appears. Click OK to continue. The messages database is restored to the BlackBerry smartphone.
  9. Click Back.
  10. Click main menu to return to the main menu of the BlackBerry Desktop Manager.
take care
May 30, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Can't load character: Xbox 360
bring your game to game stop or game crazy they might be able to help
Feb 07, 2010 | Square Enix Final Fantasy XI for Xbox 360
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
Msgs light on Motorola DCT3412
The red message light means that your cable tv provider has left you a message. (Next to the red message light you'll see a faint yellow digit indicating the number of waiting messages.)
To read your messages, do the following:
(1) On your remote, press the "Menu/Settings" button once. This brings up the "Quick Menu."
(2) Press the "Menu/Settings" button again. This brings up the "Prevue Menu."
(3) In the "Prevue Menu," scroll down and select "Messages."
(4) Read the waiting message by pressing the "OK/Select" button on your remote.
(5) To exit the Prevue Menu, press the "Menu/Settings" button.
Nov 24, 2007 | Televison & Video
Freeezing
Hi. The symptoms you described may be due to corruptions in the player's music database (this player maintains an information pool on the music files you download to it). To resolve that, you would need to delete that database and let the player re-create a new one. To delete the corrupted database, let's do this: Step 1: Switch your player to MSC mode Step 2: Browse the player in "Windows Explorer", and look for the folder named "System" and/or "Data". Note: if you can't locate these folders, your Explorer may be configured to "Hide" system files and folders. To change that, please go to "Tools" on the menu list on the Explorer window, then choose "Folder Options". This will display a Window arranged in tabs. Select the "View" tab, find the "Hidden Files and Folders", then choose the "Show Hidden Files and Folders" radio button Step 3: Under the "system" or "data" folder on the Sansa E260, look for this file and delete it: "PP5000.dat" Step 4: Safely remove your Sansa E260. Then power it on. Your player will now either display "Rebuilding Library. Please Wait" or "Finalizing Update". Either way, it would re-build the database and hopefully resolve the error your player is encountering. I hope this helps. I love the Sansa E260!!
Mar 15, 2007 | SanDisk Sansa e260 MP3 Player
Motorola Mobility A1200 Logo
1,225 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
