Goodman gsh130301ba my home was built in 2009 with 2ea Goodman units. At this time one is leaking. Who do i contact for assistance since the unit is still under warranty?
SOURCE: leaking air conditioner unit
The problem maybe the same I am having. I have condensation forming under the drain pan do to the temp. difference from the cold water on top and the warmer air below the pan. To correct this I installed fiberglass insulation under the entire pan to keep the temp. Constant. This will prevent warm air contacting the bottom of the pan causing it to sweat. Chris lathearts1@aol.com
Posted on Aug 22, 2007
kstfas
  • 75 Answers
SOURCE: goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Posted on Aug 31, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman a/c unit
Look at this forum and others as well. You will see many issues with Goodman products. Believe the old saying "You get what you pay for!". Carrier, Trane / American Standard, Payne.
Posted on May 27, 2008
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
  • 89 Answers
SOURCE: I have a Lenox airhandler indoor CB29M-31-1P
Yes
Posted on Nov 03, 2009
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
We installed a goodman heat pump in Nov 2004 to replace the goodman heat pump that was installed in the new house we bought in 1991. We looked the years of service we got out of the old unit which is why...
WELL THE TECH SHOULD HAVE A LEAK DECTOR AND CHECK THE COIL AND LINE SET FOR LEAKS THE REFRIGERANT IS LEAKING SOMEWHERE THAT DOES'N HAPPEN IF NO LEAK. A LEAK CAN CAUSE ALOT OF OTHER PROBLEMS
Aug 11, 2011 | Goodman Heating & Cooling
Not cooling, water is leaking around the outside unit. plus ice has formed around hose on the unit outside. goodman model number gsh130421ac.
take a garden hose and wash the unit real good,if the unit outside cant breath this will cause it to freeze up
May 16, 2010 | Goodman CKL36AR36 Air Conditioner
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Goodman air conditioner not running
2 summers ago, exact same problem with one of our two units outside. contractor that installed the unit when home was built was not helpful and not able to come out. another a/c company explained they would not be able to make it that day, but offered knowledge that often times in my area (San Antonio, TX) ants get into the electrical contacts of the mechanical switch and block the current.
following instructions to trip all the breakers inline and checking this it was confirmed, i cleaned the contacts with pencil erasers (a trick i learned with model car electric leads) and sure enough it's still working 2 years later.
believe it or not the same year my water well had the same symptoms and it turned out to be the mechanical switch was blocked by ants also!
Jun 04, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c unit
May 27, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
