Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Water sits in ice capture bin - Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Make sure pump is operating and drain line is not stopped up.
Posted on Sep 23, 2014
Cant find eyes that sense when the bin is full
Pull front cover off, pull the white plastic deflector off which covers the cube plate, pull the gray plastic ice deflector which sits in the water sump tray. now reach back and down where ice falls through into bin on each side and pull them straight out to the side. You can locate them buy following the wire from the controller to the bin eyes.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I CANNOT GET MY ICE BIN BACK IN PLACE IN ORDER TO MAKE MORE ICE I have a whirlpool side by side with ice/water in the door. the buck will not go back in place either i'm missing something or i'm an idiot.
You prob have to turn the gears in the rear of the fridge. Make sure you can get the bin in the tracks it sits in correctly then check to see if the gears on the auger motor line up properly so it can seat properly into the bin. Lmk if you need more help!
Aug 04, 2013 | Kenmore 57029 Side by Side Refrigerator
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Changing ice maker for fridadire part # FrS26zrg
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Dec 08, 2012 | Frigidaire FRS26ZSG
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
No water going to the ice maker
You could have either the ice maker causing this or the side of the water control valve that feeds the ice maker is defective. Here is a simple test to see which is causing the problem. Fill ice maker with tap water. If after the water freezes the cubes drop into the ice bin then the water does not refill it will need the dual water control valve replaced. If ice just sits there then the ice maker needs to be fixed or replaced depending on your Maytags model number. Let me know the model number and results, Thanks, Sea Breeze
Mar 18, 2010 | Maytag Refrigerators
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Jan 16, 2009 | Hoshizaki KM-1600S Stackable Crescent...
Ge ice maker stoped working
Check out the tray heating element that is designed to melt the ice slightly so it can be scooped out into the waiting tray.
If there is no water or ice in the tray, then check out the solenoid that allows water into the system.
Apr 19, 2017 | GE LightTouch GSC23LSRSS Side by Side...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
111 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
