Question about Garden
Troy bilt lawn mower
I have a troybilt push mower with Honda 160cc engine, bought March 2010 at Lowes. Use it maybe 5 times a year. The mower started vibrating, I look under it and the three bolts holding the engine to the frame or housing are cracking off, ie, the housing is cracking all around the bolts, two spots competely separated, the other one barely holding on...is this a common problem, is it fixable?
    Sergeant:
  • 340 Answers
This is not a common problem. The bolts are at fault. You can replace them and it will work but make sure they are the right bolts and you put them in tight.
Posted on Jul 15, 2013
  • 68 Answers
SOURCE: lawn mower
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Posted on Apr 26, 2009
  • 10865 Answers
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
Posted on May 06, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
SOURCE: My lawnmower won't start
my lawn mower has a new battery but will not start
Posted on Nov 02, 2009
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Timing for honda 160cc engine
If it is cam timing you are after there are marks on the camshaft matching the crankshaft that need to be lined up when assembled, if you after ignition timing it is pre set by the location of the flywheel key and ignition coil, but why do need to change the timing?
Jun 05, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I have a 2006 Cub Cadet Push mower with a 5.5 160cc Honda Engine. I have never had any problems till last week. The engine started racing while mowing. I stoped the engine and checked the oil and air...
Replace engine, only 1 yr. warrenty. Engine about $119 at Harbor Freight. Easy to change out. all Harbor Freight engines are Hondas. Bolt pattern same. 160cc or 190cc will work. Remove blade, remove mounting screws, replace engine. Carb may be the same for throttle connections. Reinstall blade. 10 pulls required to start engine 1st time. 1 pull after that. Pull 1/2 way 4 times 1st to prime even if you use the primer bulb. Ensure oil is full, 30w oil. Excellent engines good for 7-8 yrs with proper maintenance. Observe cable connections before old engine removal. Take pics.
Sep 14, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Model TB110 rand great first few times but will not run now. Cranks but run rough and dies. Only had 6 weeks. Lowes say they can't help me and I just need to have it serviced! After 6 weeks? Give me...
My name is Dane. Troy-Bilt says this mower has a 2 year warranty with a briggs engine. According to troy bilt, that engine is suppose to start in 2 pulls or they fix it for free. Take it to a local briggs dealer and get them to look at it. I would hate to have you try something and you void your warrenty somehow. Here's the link to the website.
http://www.troybilt.com/webapp/wcs/stores/servlet/product_10001_14102_1410819_54968_-1
Hope this helps you... Thanks....Dane
Dec 02, 2010 | Troy Garden
I have a Troy-Bilt Mower - Model 834. It has a Honda GVC 160cc engine. It is supposed to start after two pulls when cold and did so since I bought it in 2006. But, just recently it takes 6-10 pulls to...
sounds like the throttle cable has slipped on the side of the engine if they dont pull the choke all the way on they wont start too well. one way to find out is take your air cleaner and outer cover off so you can see in the front of the carby the put your throttle on start/choke position the choke butterfly should be closed if not check your cable.
Jul 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
