Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Blades won,t disengage
When I disengaage blades they do not stop. When I start the mower, the blades rotate immediatly wether I engage lever or not
  • Andy Harris Jul 14, 2013
    Lubrication helped. Found the idler arm with a notch worn into it. Ground smooth and it is a little better. Looks like it's time for new parts.
  • Rick Jul 15, 2013
    Andy when you do put the new parts in you may want to put anti seize on all of the contact parts to slow down the rust build up. I've found that helps alot.
    Scholar:
    New Friend:
  • 61 Answers
Assuming this is a lever actuated deck (not electric p.t.o style) I would be checking the belt pivot tensioner assembly which the cable would be hooking to a lot of times moisture will get between the pivot and the deck and rust up not allowing the heavy return spring to slide the pivot back removing the tension from the belt. If you spray the pivot with a good lubricant and hand work the pivot tensioner back and forth it should loosen up. Usually it's the other way around and the 1st time of the year you use it you can't get it to engage.
Posted on Jul 13, 2013
5 Suggested Answers
  • 2239 Answers
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Posted on Jun 24, 2012
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
  • 146 Answers
SOURCE: I cannot disengage the cutting attachment so that
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Posted on Jul 04, 2010
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Did not press the RIO when going in reverse with the blades engaged. The motor stopped for safety reasons. Now I cannot get the mower started. Any ideas?
What model machine, and are blades engaged by flicking a switch or by actuating a lever.
BUT .... did you place machine in neutral, apply parking brake and disengage blade PTO before trying to re-start ?? Machine's safety system needs to be satisfied that the machine is safe to re-start.
Oct 30, 2013 | John Deere Garden
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Oct 31, 2012 | Husqvarna Garden
Blade engagement lever won't disengage
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
Jul 03, 2010 | Craftsman Garden
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
Oct 17, 2009 | Craftsman Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
171 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
