Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Managemylife com searsThe blades on my lawn tractor will not disengage. How come?
  • Craftsman Master
  • 2,478 Answers
Belt to tight
Posted on Jul 14, 2013
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 4 Answers
SOURCE: lawn tractor will not move
Check Drive Belt To Transmission
Posted on May 25, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Craftsman LT2000 tractor and I've had a
the pulley that the disingage spring is hooked to sounds like its freezing up it may need some oil put on it to make it slide easier
Posted on Oct 26, 2009
  • 17 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
Sounds like your drive belt may have came off or it needs to be replaced. Take the battery out from under the seat to see if belt is still around transaxle. Sometimes it will jump off when doing a lot of starting stopping
Posted on Aug 04, 2010
Testimonial: "Bang-on, Barny. Many thanks."
confloyd
SOURCE: My riding lawnmower blades will not disengage or
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Posted on Jun 08, 2012
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Craftsman tractor #917276905 engine dies when blades engage ?
owners manual
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0704327.pdf
unfortunately, they opted for spanish instead of parts breakdown and wiring on yours. check out this manual which may be for a similar model. wiring is on page 33 and 34
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0312062.pdf
Jun 25, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
Managemylife com
check that the cable isnt unhooked
May 01, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
