Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Removing the lid from a hayward power-flo matrix
I have a Hayward power-flo Matrix pump and can not get the top to come off. I am turning it in the right direction but can not get the top to rotate. Prior to putting my pump together back in May it was moving freely in fact I even greased the rubber o-ring prior to attaching the hose. Could it be to much preasure causing it not to turn? Any ideas?
  • Hayward Master
  • 1,631 Answers
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Posted on Jan 27, 2014
SOURCE: Hayward Matrix Power Flo
On the right side, usually opposite the discharge. You may need to use a butterknife of flat head to push it in; push in and turn.
Posted on Sep 04, 2009
SOURCE: No water in pump after running for short time
suction side leak... your grabbing air somewhere in the suction line.... take a hose at low pressure and with the pump running put it over various parts of the suction line... including your pump lid... if the problem goes away and you have no more air in the pump then you know what your problem is
Posted on Jun 03, 2010
  • 8404 Answers
SOURCE: Hayward Matrix Power Flo 1.5 hp It started
Replace your faulty impeller.
Posted on Aug 09, 2010
john224
  • 1378 Answers
SOURCE: I have a power-flo matrix pump from hayward. The
Thank you for posting your question here on Fixya.com.
It is likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
As a rule it is not worth 'rewiring' these motors as the cost to replace them is so low.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 28, 2010
john224
  • 1378 Answers
SOURCE: All I want to do is find a replacement switch for
Please post the model and serial number from the motor. The number you have is the part number Hayward assigned to the AOSmith motor on your pump. I'll need AOSmith's info to get you pricing on the correct switch. Do you need the stationary only or the stationary and govenor?
John
Posted on Oct 23, 2010
Hayward power flo leaks
If it is just dripping a little and it is outside don't even bother until to freezes up. The pool will evaporate much more water than is leaking through the pump.
Jun 08, 2014 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
How to replace seal on hayward power flo matrix?
if seals leaking ruining bearings next to go replace whole unit
Jul 21, 2012 | Hayward 1hp Power Flo Matrix Above Ground...
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
How to install a power cord to a Hayward 1hp Power Flo Matrix pump.
One line lead wire to the L1 terminal, the other line lead wire to the L2 terminal and the green ground wire to the green grounded screw above the motor terminal board. It does not matter which wire, white or black, is on which terminal, L1 or L2, so long as one wire is on each terminal.
John
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
May 22, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
163 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
