Question about Motorsports
How to change front parking bulb in C240 Mercedes 2003 ?
  • 4 Answers
I don't know
Posted on Jul 13, 2013
My car go from drive to park unless i turn it off. It also will not change gears when i try to drive it. Mercedes 2003 c240
You need to see a transmission shop but I suspect the transmission has a internal part failure
Aug 20, 2016 | 2003 Mercedes-Benz C-Class
How can I take out my front headbeams for my Mercedes Benz 2003 C240
hi here is a video wouldent think you would have to remove bumper but you might http://www.youtube.com/watch?v=dSxs47TeGo8
Nov 17, 2012 | Mercedes C-Class Exterior Pillar Posts...
Model: 2003 C240 problem: wiper blades "park"
model: 2001 C240 problem: wiper blades "park" almost in the middle of a windshiled when turned off. When wiper blades are on they cover complete range of a windshiled.
Feb 01, 2011 | 2003 Mercedes-Benz C-Class
How to replace mercedes c240 trunk lamp bulb
Pry the lamp assembly off with a flat screw driver, you must pry it off from right to left only. do not pry in front or back or on the left because you will damage the assy. This works for a MB c240 2005.
Dec 10, 2009 | 2007 Mercedes-Benz C-Class
HOW DO YOU CHANGE THE HEAD LAMP BULB ON A C240 MERCEDES
remove the rear cover on the back of headlamp, then unplug the connector, then you will see a metal clip that holds blub in, gentle push it in and down a little then release slowly, swing it open now pull bulb out,take note of position of bulb, ( there is a slot on matal part of blub) insall new one in the same position reclip to hold bulb in then connect connector and install cover, good luck.
Nov 13, 2009 | 2003 Mercedes-Benz C-Class
C240 mercedes wont start. after backing into a parking spot?
check for fuel pump operation.have someone turn ignition on while you go to rear of car where fuel tank is to listen for fuel pump operation.if not.check fuse and relay.if you hear fuel pump .check ignition system to make sure engine is getting spark.
Jun 06, 2009 | Mercedes-Benz C230 Cars & Trucks
MY WILL NOT START THE CAR C240 MERCEDES BATTERY IS NOT DEAD
I am assuming that the engine won't even turn over. could be lots of different things. The simplist is to make sure the car in in PARK , won't start if not. Other things could be , Security imobilizer if you have one. Does your key have a electronic chip in it ? Try your other set of keys if you have one. Check if battery connections are clean and tight.
Jun 04, 2009 | 2003 Mercedes-Benz C-Class
Motorsports Logo
47 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
