Question about Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV
Insignia lcd tv picture is washed out even menu
SOURCE: set up menu
Hi - if you have this hooked up to a TV cable HD box, you have to make sure you hit "TV" on the cable box remote in order to set up the TV menu. I had to figure this out also with my Insignia 32" LCD TV.
Posted on Apr 18, 2007
dahaka
  • 347 Answers
SOURCE: insignia lcd tv
Hi em jay,
What do you mean? Your TV is too bright?
Posted on Jan 11, 2008
  • 814 Answers
SOURCE: Bought a 19inch LCD Insignia TV yesterday at Best
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
Posted on May 20, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
freelance-au
  • 131 Answers
SOURCE: insignia 32 HELLP
PHIHONG - PSM210-417A-R
Rather than spend hours and time on the kit, these guys have the board in.
Posted on Nov 18, 2010
My Insignia NS LCD 37 will power up but the screen is gray and there is an even lighter gray bar going up and down but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | Insignia NS-LCD37 37 in. LCD TV
Video goes out on insignia lcd
An lcd tv has to have a light source behind it to see the picture. Older ones have flouresent tubes. Newer set have light emiting diodes(led). You need to determine if the backlight is turning off or is set loosing signal. If you press the menu button on the Insignia remote does the menu appear on the screen. If not hold a flashlight on the front of the screen. if you can slightly see some video the the back light is off. If the menu shows then check the signal source. If back light is out the replace the inverter board.
Jan 07, 2014 | Insignia IS-LCDTV32 32 in. Television
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
Whats the best picture settings for 42 lcd insignia tv
Hello
55% Contrast, 35% Color and brightness to match will give you a vivid picture to your TV.
Mar 05, 2012 | Insignia 42" LCD Flat-Panel HDTV
I'm trying to find or download your user guide....but in the meantime, I would like to know how to get the picture to be full screen on my new insignia 32" tv??? Thank you.
check the remote and menu for format options. the remote may have a button that says "format" "size" "aspect" "wide" the tv menu will have an option to change the size in either the picture settings or something like that.
Jan 06, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
The tv screne picture on my insignia tv is off centered and is split in two
I suppose your TV has a PIP function.
  • check if u have a PIP function on your remote control or
  • Go to the Menu n in the display see if u can see the PIP function or the Aspect Ratio function like 4:3 or 16:9.
  • You have to switch it to standard or normal view to change to one full picture.
Jun 04, 2009 | Insignia NS-LCD19 19 in. LCD TV
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
May 15, 2009 | Insignia LCDTV26 26 in. Television
Set up menu
Feb 11, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV Logo
23 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
