Question about Philips Magnavox DVD/VCR Dual Player
Dvp3010 stuck disc
We have a disc stuck in our dvp 3010 dvd player and are unable to open it using the remote or front panel. We do not see a way to manually eject it and was wondering if there was a way
SOURCE: DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Posted on Sep 27, 2007
ANDREIONELUV
  • 29 Answers
SOURCE: philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Posted on Jan 15, 2009
SOURCE: REMOTE CODE FOR PHILLIPS DVD DVP3140
I don't know if this will work for you since your Philips universal remote is a different model. I tried all the codes listed for a Philips DVD player in my Philips SRU3004/27 universal remote manual. Two of them partially worked (wouldn't let me scan forwards and backwards). The last one they listed did work, code 1214. I suggest trying all the codes in the handout that comes with the remote for Philips DVD players. Make sure each number you press registers (the indicator light on the remote will blink). Philps also lists these codes on their web site. Good luck!
Posted on Feb 01, 2009
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
Dec 22, 2008 22 joulukuu 2008 - It began that I could not play CD's. - Se alkoi siitä, että en voinut soittaa CD. Now my DVP3010 dvd player is not able to play DVD's too. Nyt minun...
Please replace your DVD drive. There is a problem on the motor and reader of the DVD Drive. If your continue using this drive it will damage your disk. Have it replace so that it won't create errors upon using it.
Aug 12, 2010 | Televison & Video
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
My Sony DVP CX860 DVD/CD player is jammed
You can unscrew the top panel. (Two screws on either side, three along the top in the back.) That will allow you access into the unit.
Inside the unit the lense and spindle are encased inside a shell in the center. If there is a disc jammed in there it will require some effort to get it out without damaging your machine. Be sure that it is unplugged to avoid a shock and I would simply attempt to fish it out through the front or back slot.
There's also the possibility that if you unplug it and replug it, the machine will eject the disc if you loosen it up or get it back on track.
Aug 19, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Cannot insert disc
If the problem is with the tray of the player, there will be a small hole at the front panel near the tray. You just need to put a pin into that hole, the tray will come out if it is stuck inside.
Thanks
Aug 09, 2009 | Sony DVP-CX995V Multi-disc DVD Player
I HAVE A DISC IN U.K. AND EUROPE REGION . BUT CAN'T PLAY MY DVD PLAYER. HOW CAN I PLAY THE DISC IN OUR PLAYER? MODEL IS DVP 3256 ,DVP 3258,DVP 3268 . WITH USB . ANY OPTION TO PLAY THE OTHER REGION DISC....
HELLO
This sounds like the old problem of your player trying to play a disc from another region, when your player is set for another. What you need to do is HACK the player and set it for ALL REGIONS (0), usually via the remote control.
Try this website for DVD player hacks: www.videohelp.com
You will find hacks for many makes and models listed here. Contrary to belief, it is NOT illegal to hack a DVD player.
Aug 03, 2009 | Philips DVP3960
Philips Magnavox DVD/VCR Dual Player Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
