Question about Garden
Poulan pro bvm200vs
It won't start. Tried some starter fluid even in the air filter, even. Only 2 months old. It ran fine, then now won't start. Same fuel as before.
    New Friend:
  • 19 Answers
Take off the muffler and you should see the piston and ring..with a small pick push at ring to see if it moves. If no movement, you have carbon buildup from too much oil in fuel. Remove cylinder and carefully try to free the ring.
Posted on Jul 16, 2013
5 Suggested Answers
pippall
  • 1486 Answers
SOURCE: Hello, I have a Poulan Pro 25cc gas blower, 1 -
Remove the spring loaded screw.Then clean the end of it.Replace it.Screw it in tight and then losen one and a half turns.hope that was helpfull.
Posted on Aug 01, 2009
  • 11 Answers
SOURCE: My Poulan Pro BVM200VS leaf blower just stopped
sounds like an engine seizure - was there oil mixed with the fuel?
Posted on Oct 25, 2009
SOURCE: reattach pull cord for poulan pro bvm200vs
how to replace cord in apoulan pro gas blower
Posted on Mar 27, 2010
SOURCE: my poulan pro bvm200vs will
Problem is likely a stuck needle valve or ruptured diaphragm causing flooding -- a carburetor rebuild is indicated.
Charlie
Posted on Mar 27, 2011
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Have Poulan BVM200VS 25cc gas blower. It has compression, is getting fire and has fresh fuel mixture. Will not start. Any suggestions? It is less than 1 yr old.
By luvcatzlotz on Sep 08, 2010
Answer: I have the same problem. Thats why the company is called Poulan.. Because thats what you do half the time when you own one. PULLON the starter cord...............
Sep 08, 2010 | Poulan Electrical Supplies
I HAVE A POULAN BVM200VS BLOWER...WON'T START I HAVE PULLED THE FLYWHEEL AND KEY IS INTACK...I HAVE A SPARK AT THE PLUG..REMOVED CARB AND CLEANED....REPLACED GAS WITH FRESH GAS..SET GAP ON IGNITION MODULE...
If you have a spark, it's not your ignition or flywheel because they both work together to make the spark.
Give a starter fluid squirt into the sparkplug hole (instead of thru the carb), screw in the sparkplug and give it a try.
Check your muffler to see if it's stopped up. You can just remove it for the initial check when trying to start w/starter fluid.
Oct 07, 2017 | Poulan Garden
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
