Question about Craftsman Garden
Craftsman walk behind lawn mower 917.376722
How do i attach a drive cable
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
steve_lima
  • 181 Answers
SOURCE: I hit a big rock with my walk behind lawn mower
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Posted on Jun 29, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Why drive lever pushed down does not engage the front wheels of my yard machine lawn mower ?
if everything else is working fine then it has to be your drive cable or the drive motor itself. First check to see if it feels as though the cable is actually moving, slid the lever back and forth, if there is no resistance then the cable has become unattached at the lever. Next is to see if the cable is attached at the other end. you will need to follow the cable and remove the cover that to see if the cable is attached to the drive. Also, is your drive belt good? loose?
Aug 11, 2014 | Yard Machines 11A54MC006 21Inch 139cc MTD...
How do I check the cut off switch?
If the oil is low, it will not start.
Jul 14, 2014 | Craftsman Garden
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Installing blade engaging cable on 46 inch craftsman deck
If you will take the 917. model number and go to http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Walk-behind-lawn-mower-Parts?SID=PSx20071217x00001d&creative=2064608&adcid=7718792 You will get a complete exploded view to help guide you.. If I can help in any way, please let me know..
Apr 25, 2014 | Craftsman Garden
How to attach drive cable 406259 on husqvarna model 917.376820
This is hard to explain over a computer. I found a diagram of your make and model. I would try using a long end needle nose pliers to attach spring. I hope this helps. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Dec 07, 2013 | Husqvarna 7021R 21-Inch 160cc Honda GCV160...
Install a new harddrivw on the optiplex gx620
Two wire are needed to attach a new hard drive.
Please refer to the links below ,to see how the attaching cables looks.
This cable is connects Hard drive to Motherboard
SATA Data Cable
This cable connects Hard drive to Power Supplier
SATA Power Cable
Jun 07, 2012 | Dell OptiPlex GX620 PC Desktop
Can't detect the usb drive, have noise
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Aug 18, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
Garden Logo
63 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
