Question about Pioneer PRO-200 60" Rear Projection Television
Manual how do get the tv to get channels like 11-1 or 13-1 it will not let me put those # in
    Champion:
  • 247 Answers
Use the cursor program button after reaching eleven and cursor or press up and u will go to the upper numbers or check the 11-1 and 13-1 u may have marked the range as SKIP just deactivate skip on the menu settings and u will be able to enter them
Posted on Jul 14, 2013
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
Finding the AV Channel on a TV
There may not be one on your TV. If your TV has audio and video input jacks then keep changing channels going from high channels to lower ones. When you get to Channel 2 then the next one down should be AV. If your TV doesn't have the A/V input jacks, then you'll need a modulator. This will take the audio and video outputs of the DVD player and put them on TV channel 3 or 4 and insert it into the antenna connection of the tv.
Jan 23, 2014 | Televison & Video
Cannot get it to change the channel to recieve cable from the cable box. it says it is on channel 2.1
If you are using the channel up and down buttons, sometimes it will skip channels. Try manually putting in 03 using the remote to change to channel 3. Also make sure that in the TV menu you have the TV set to Cable instead of Antenna.
Jan 13, 2011 | Sharp LC-19SB14U 19 in. LCD TV
How do i put it on channel three manually?
If the remote to your box can be paired with your tv then you should be able to fix this problem simply by pairing digi remote with tv and while in tv mode on remote, hit the input button. That should change tv back to cable/antenna setting so that you may access channel 3. Hope this was helpful.
Jan 27, 2010 | Symphonic T19WF 19" TV
I do not have the manual for my JVC TV. Having problems setting the proper channel number to get my Directv stations
Use a generic universal remote. Program the remote to your JVC tv. Use the newly programmed remote to put your JVC tv on channel 3 (or 4) or the appropriate channel for Direct TV.
Aug 13, 2009 | Televison & Video
Channel changing Problem
when you hit auto channel the tv  start to check the signal incoming
and put in memory the good signal - i think your tv is functioning
you have to use the channel on manual for   put in memoty what
you need- delfo
Mar 20, 2008 | RCA F32718 32" TV
Getting it plugged in right to work with tv set
you dont put it on channel 3 like a vcr. you put it on video input like you would when playing a game.
Mar 10, 2008 | TruTech TT1620 DVD Recorder
TV not storing vcr channel
most newer tv's wont store the channels if the channel isn't always putting out a signal. not much you can do about it
Oct 31, 2007 | Televison & Video
Pioneer PRO-200 60" Rear Projection Television Logo
64 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
