Question about Kitchen Appliances - Others
Propane fryer is igniting in the gap below the burners
  • Kitchen Appl... Expert
  • 683 Answers
Hi there.
Low gas pressure may cause the tip of the orifice to light up during operation, you have to ensure that the gas pressure fed to the unit is correct. But when this happens after cut-off, the gas valve's main valve is leaking and needs to be replaced.
Regards.
Posted on Nov 22, 2013
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
  • 19 Answers
SOURCE: dean french fryer need new burnners
http://www.a1service.com/dean/deanburner.htm
Posted on Feb 05, 2009
  • 30 Answers
SOURCE: burner doesn't ignite
did you check to see if the knob on the gas valve is set to on?
Posted on Mar 31, 2009
SOURCE: Regulator problems
Sounds like your regulator is faulty, I would start there. Be sure any regulator you have installed is installed correctly, not backwards as reversed regulators will not work properly. Also be sure to keep regulators clean, there are breather holes in regulators to break vacuum when the regulator opens and closes, if these are clogged the regulator will not open or close properly. Hope this is helpful.
Posted on May 01, 2009
  • 81 Answers
SOURCE: IMPERIAL FRYER
Replace the thermostat
Posted on Jul 25, 2009
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
Pitco 45C-S propane fryer is igniting in the gap below the burners
Hi there.
Your unit is probably receiving low gas pressure, make sure that the incoming gas pressure complies with the rated as shown on nameplate.
Or your gas valve has leak on main valve if the small flame is visible on burner orifice after the cut-off.
Regards.
Jul 13, 2013 | Kitchen Appliances - Others
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have two pitco fryer natural gas that I like to convert to propane please help
Hi there!
You will be needing a gas valve conversion kit (nat to propane),
propane pilot orifice and burner orifice (depends on number of burners).
You will find these parts awhen you visit http://www.pitco.com
Regards.
Jul 04, 2012 | Kitchen Appliances - Others
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Frymaster blowing back fire
google sams manuals.is your fryer propane or natrual gas if so the baffles and orfices in the fryer are clogged.propane burnes very dirty.
Aug 12, 2007 | Frymaster Dean 2424G Deep Fryer
Kitchen Appliances - Others Logo
32 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
