Question about Kenmore 62602 Electric Dryer
696891 dryer kenmore
Dryer motor runs but does not heat up
  • 122 Answers
SOURCE: kenmore dryer no heat
If the dryer runs - but no heat is produced, there are usually two things that it would normally be - first turn the dryer on and go outside and check the flow at the duct. If the flow at the duct is weak (should be nice and strong) then you more than likely just have a clogged up duct - clean it out and you should see a big difference in airflow and time to dry things. If the air flow is good but there still is no heat - you may have a heater bank that went out, or a hi limit switch that was set
Posted on Nov 22, 2008
SOURCE: KENMORE DRYER PART NO 696891
My dryer keeps breaking the belts for no reason. I am going to take it outside and beat it with a 10 LB sledge hammer and set it on fire!
Posted on Nov 27, 2008
  • 1382 Answers
SOURCE: Kenmore Dryer 97272100 Dryer runs but no heat
You should have your owner's manual on hand to locate specific parts and understand how to disassemble the dryer. Also make sure that the power is disconnected from the appliance before making any repairs.
1)Check the fuses near the heating element. Inspect them for breaks inside the fuse. Replace them if necessary.
2)Test the temperature switch with a volt-ohm meter. Set the meter to RX1 and zero it out. Touch the meter probes to each terminal on the switch. The reading should be zero. Next turn the switch on and test it again. Now the reading should show infinity. If the switch fails either test replace it with a new one.
3)Check the heating coil to see if it is bad. Use the volt-ohm meter and touch the probes to each of the heating coil terminals. If it reads zero, the heating coil needs to be replaced.
Posted on Aug 29, 2009
  • 2128 Answers
SOURCE: Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Posted on Nov 19, 2009
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore 80 Series No Heat
The heater gets one leg of power through the timer and one leg through the motor terminal.Make sure power is leaving the timer and terminating at the heater. Check the switch on the motor for continuity for the other leg of power.(The motor must be running to check this switch).
Aug 24, 2009 | Kenmore 63942 Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
Sep 27, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore Dryer
If the motor can run, check the fuses in the house's panel. Electric dryers run on two phases of the 220-240 volts outlet; the motor on one phase, the heating coil on both phases. One of the two fuses may be burned out.
REMOVE the fuses before touching any component inside the dryer's housing.
If the fuses are OK, check if the the switch resting on the motor itself, has not burned terminal or wires.
Check if the heating coil is opened (burned)
Nov 07, 2007 | Kenmore 63942 Dryer
Dryer runs no heat
the kenmore is manufactured by Whirlpool. there are thermal overloads in the blower housing and one in back where the elements are. if these overloads open, 1) motor won't run 2) element won't turn on. check for an obvious open element.
Sep 13, 2007 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
