Question about 1995-98 Chevy/GMC Silverado/Sierra 1500 4WD 3 Body Lift
1995 gmc sierra 1500 305 cu. starts but stalls after warm and upon acceleration
The engine starts, but after warm chugs and sputters then stalls out when accelerating. then hard to start after that. must put pedal to floor to start, should'nt have to do this with a throttle body..
    Top Expert:
  • 21,873 Answers
Have you checked fuel pressure when the engine is cold and when it is warmed up ?
Is the check engine light on ?
Posted on Jul 13, 2013
I have a 93' sierra 6 cylinder 2 wheel drive, once engine warms up it sputters and loses power. If you shift from drive to reverse it stalls and won't start. When engine has cooled it starts like a champ...
The problem may be the engine coolant sensor. If the sensor fails the engine will stop when normal operating temperature is reached . When engine is cold it will start.
Jan 20, 2011 | 1993 GMC Sierra
From red light truck started sputtering and and stalled out
Hello. The GMC Sierra has an electric fuel pump so you should ensure that its fuses and relays are working before checking it. You may need to clean your fuel pump or replace it if your gas tank is not empty, but your vehicle has difficulty getting fuel. The GMC Sierra comes in a variety of styles and trim levels that can affect the replacement fuel pump you choose.
Mar 02, 2010 | 2003 GMC Sierra 1500
1998 GMC Sierra- runs rough then stalls when
had this problem on my neighbors 98 chevy truck with the same engine !!
it turnd out too be the fuel pressure regulator,you have too pull the upper intake too replace it!!
Jun 04, 2009 | 1998 GMC Sierra
Chevy S10 Pick 1995 - Sputters and almost stalls when accelerating.
You could have a dirty EGR valve, you can re move it from the manifold and clean it with Throttle body cleaner. Might as well buy two cans, since your cleaning the EGR, might as well clean out the throttle body too.
Spray the throttle body cleaner in to the throttle body with the engine running and try to keep it at 1000 rpm and then to 1500 rpm as you clean out the throttle body and let it idle down for 2 min then turn the engine off. Then turn the engine to the run position for 10 seconds and start and let idle, ro for a test drive and hope that solved the problem, if not there a few more things we can do which will consist for tune up.
Note: Clean the EGR first so you don't burn your self since the engine would still be cool before you clean the Throttle body.
Good luck and keep me posted.
Jun 01, 2009 | 1995 Chevrolet S-10 CA Edition
Low oil when engine warms up gmc sierra 1995
30-40 psi of oil pressure is fine for many vehicles including your GMC. I am assuming that the truck has more than 100,000 miles on it and still has the original engine in it. By rule of thumb you only need 10 psi per 1000 rpms in a typical street driven engine to give adequate oil pressure to keep the bearings from oil starvation. The oil pressure is typically higher when initial start up occurs because it is more viscous due to the temperature of the oil as the engines oil warms up the visconsity thins out and the oil flows more smoothly. The drop in oil pressure is a normal occurance. Above 45 is more than required for a daily driven street engine. I believe that the specs on that engine only list 30- 45 psi.
Dec 07, 2008 | 1998 GMC Sierra
Sputtering, chugging, black smoke - won't restart when hot
check your tail pipe for a "clog" engine not breathing correctly.
Jun 22, 2008 | 1993 GMC Sierra K1500
1995-98 Chevy/GMC Silverado/Sierra 1500 4WD 3 Body Lift Logo
210 people viewed this question
Top Zone Offroad Products Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Zone Offroad Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
