Question about Hampton Bay Dryers
Medium botton on remote goes faster than the high speed button. The rmp's is not turning as fast as it should.
52 in ceiling fan Redington III On manual it says models 524 606 523 971 523 974 524 495.
  • 52 Answers
SOURCE: 52 in. redington III cieling fan
Did you have to wire in the remote? If so you prob hooked up the light to constant power source. more info on number of wires on remote unit and wires on ceiling fan pls.
Posted on Jan 29, 2008
SOURCE: Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
Posted on May 27, 2009
SOURCE: Hunter 52" ceiling fan model 23457-380, the remote lights up
check the hard wiring from the factory. Where the light kit attaches to the fan check the wires in the factory cubes to make sure none are coming off. I had a similar problem that kicked my **** for a few minutes but I saw a loose wire after a bit of research. My fan also clicked but never turned on. Also pull the chains on the fan/light to make sure they are on. Hope something works for you.
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: my hunter remote control ceiling fan doesn't go
I've seemed to have lost med. speed on my hunter. I have high, 2 lows, then off. Is there a fix for this?
Posted on Jul 28, 2010
My Redington IV ceiling fan with remote controller is stuck at low speed. I can turn on/off light and on/off the fan but can't change speed. It just happened recently after about three years of working...
It's possible the fan is in reverse and some fans will not on function faster or lower speeds, check for a switch on the side of the fan just above the blades.
May 27, 2011 | Hampton Bay 52 In. White Redington...
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
Hampton Bay Deluxe Ceiling Fan SKU: 293972 Never got any but high speed. receiver # as-cf118??remote has 3 speeds. What is wrong?
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
May 27, 2009 | Hampton Bay 52 In. White Redington...
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Speed
The Receiver for the remote is defective. Try calling the toll-free number listed on the top of the motor housing of the safety label.
Jun 26, 2008 | Hampton Bay 52 In. White Redington...
Dec 11, 2007 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
26 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
