Question about Kenmore Refrigerators
Kenmoreelite trio refridgerator 79579753901
Fridge is not getting even after changing power control module
2 Suggested Answers
  • 24 Answers
SOURCE: Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Posted on Mar 15, 2009
My kenmore trio refrigerator ice maker is not producing ice, inside the fridge my milk spoils but my eggs get frozen any ideas?
Am surprised your refrigerator is 'blowing hot and cold thru the same mouth!. Try turning the power off and keep the doors be open for 12 hrs. Wipe off water under the fridge and turn on power.Good luck.
Mar 08, 2014 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore trio freezer and refridgerator not cooling
Sounds like you have a relay switch or igniter not working. If it is less than 6-8 years old, this probably,is the problem.
Feb 10, 2013 | Refrigerators
Whirlpool Refridgerator Model # ET1FTKXKQ00 My Question: I can not seem to locate the hose that would take the moisture from the freezer/fridge to the evaporation tray at the bottom. My fridge is...
Hey i think they freze free lol and thers no tubes they are connected by chanels/ tunels blockes at the back fron freezer down. Reg temp yr nobe controler could b gone or temp module. So thats why it wont help lol check if the temp changes after yr turning it, so atleast u can iluminate that.. if it is working. Than i would sugest next checking yr front doors rubers and magnets on them all the way and both doors.. as wen it gets old it could b having gaps so there 4 it will not close the dore properly and u wont even know or notice and if thats the case. Thats why it running inside, as it not fully and all aront germeticky closed .. hooe that helps you . G/luck ??.. Tony
Apr 19, 2017 | Whirlpool Refrigerators
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridge compartment warm not cooling
I hope the following helps.
Turn the entire control system off for at least two minutes. This will give the computer module time to reset to factory default. Turn of to desired level after two minutes. Should that not work then there is a problem with the timing relay. They relay is brand specific, meaning take the model number to the parts store for a new one.
Your compressor should be fine. You may also remove the power by unplugging the refrig.
CAUTION: Before removing the relay the power to the fridge must be OFF. Failure to have it in the off postion can cause the new relay to short which can lead to mkore problems. So UNPLUG the fridge, remove the relay, replace the relay and then plug fridge back min. Set control to desired cooling level and wait a couple hours. That should do the trick.. IF not then there is an issue with the processor module.
Jan 04, 2009 | Refrigerators
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Mar 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
