The washer work but stop along the way,ie unable to complete the circle
  • odarikpe george omamode
    the board comes with a spare IC. that was what i change b4 it worked
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
See this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Posted on Jul 14, 2013
Testimonial: "yes, it was the micro processor control board.thou it was new but i just try to replace one of the spare IC and it works fine"
I just want to find my complete access and netbank saver accounts.
to log onto your accounts you will have to set up the user name and password with the bank first
If you have done that and it is still not working contact the bank and get assistance from them
There would be no one here sending you around in circles as this page has not ability to connect to any accounts . That is for the bank
Jun 11, 2015 | Computers & Internet
Whats the red key and circle llso shows a OE code on LG steam washer wm2487hwm
OE on the LG means the washer is not draining or has a draining issue. When it happened to me I started by manually draining the washer and then running a spin cycle. In a pinch the work around was OK but I could never be certain the wash was complete. Also the wife hated it.
Finally, I dug in and went for a fix. All the hoses were clear and the pump seemed to be working (also the pump screen needed clearing). I found the problem to be a breather hose that runs from the top of the drum to one of the drain hoses. It was plugged and I took it off and blew it out. Problem solved.
Aug 05, 2012 | LG Washing Machines
How do I open/unlock part way through a drying cycle?
you would hold down cancel or stop for 5 seconds usually the cancel option puts the unit into drain in which after it finishes draining it would unlock the door on the other hand if you had a door switch error and your unit was a frontload washer and you are unable to get into the unit even after the unit has stopped you would remove the lower panel on the machine and reach up along the side that has the door lock there would be a small cord with a round circle on the end by pulling this cord down this also unlocks the door this 2nd par is only for a frontload washer if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks
Rick
Mar 23, 2011 | Washing Machines
Front load GE Adora washer isn't spinning when it should. Other sites I see they talk about replacing the door lock assembly...what else could it be?
I had the same problem with my front load (different model). The pump was not pumping out the water, thus stopping or slowing the spin. Take off your pump (located under the washer in the front right on my model) and look inside to see if there is any junk stopping the plastic spinner to spin. Clean out really good along with the attached hoses. Replace (tricky!) and try the washer! I had lots of junk in the pump along with a few hairpins that stopped the sinner in the pump. This is a tricky process on my model.
Mar 28, 2010 | GE WSXH208A Front Load Washer
Unable to start IE8.... and now unable to restore system (vista)
Just use Firefox, Safari, AOL, Opera or other browsers.
Jan 12, 2010 | Microsoft Internet Explorer 8
Hi I have a AWM8143. then i start a program, the machine, takes the water in, but the drum does not move, its trying to rotate but it can't. After 30 seconnds, the machine is stopping and the display...
The machine belt will be very tighten position so that is unable to rotate else bearing may be defective kindly replace the 2 inner bearings along with washer
Dec 24, 2009 | Whirlpool AWM8143 Front Load Washer
I have a frigidaire stackable washer/dryer unit. The washer works well. But, recently, the dryer started making funny noises almost every revolution like something was banging inside at a certain point....
Try to move the drum manually. if unable to run your hand along the front of drum where it meets the front panel....there are two pieces of felt. something has either gotten stuck there or something has gotten stuck in the blower housing.
Jun 09, 2009 | Dryers
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Circles on my laundry
first lets figure out if its coming from, do you notice them before drying??? solid circle or a ring? streaks would be more a common complaint, but a complete circle?? does it come off in next cleaning ??
Feb 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
