2420 fuser Showing 50.4 FUSER ERROR. What can i do please?
    New Friend:
  • 12 Answers
This fuser error can lead up to a series of solutions, and I will list them in order of easiest to hardest.
1) Unplug your printer from the wall, wait 5 minutes and plug it directly into the wall, UPS battery backups and Surge Protectors can trigger this type of error.
2) If you have another one of these printers, try swapping the fuser roller with another one while the power is off and see if the error persists upon startup.
3) Last and least desirable, you may have a failed Engine Controller Board, which is responsible for among many things, making sure the fuser is at the proper temperature and has no tears. Be aware that this repair requires a pretty serious disassembly, and can be daunting to a newcomer.
The fuser is actually considered a part replaced with routine maintenance, around every 100,000 to 150,000 pages. It is what is responsible for the carrying the charged toner particles and heating them up to melt them onto the target paper (New HP Laserjets use a wax based toner for better environmental impact) Problems with the fuser generally show themselves as lines or splitting images on printed paper, but if serious enough (as in a tear on the roller) can cause the printer to cease printing to prevent serious damage to the interior of the machine.
Posted on Jul 15, 2013
SOURCE: error 50 code, have replaced fuser and checked connections
I am not sure this will stay fixed but after i cleaned the pcb's and checked the connections and let the unit sit overnight the printer works just fine. If this does not stay fixed I will contact you again.
Thank you,
Posted on Apr 15, 2009
MightyFalcon
  • 32 Answers
SOURCE: 50.4 fuser error
Posted on May 06, 2009
Touch2Heaven
  • 145 Answers
SOURCE: My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Posted on Jun 19, 2009
mishrajk21
  • 202 Answers
SOURCE: my hp 2420 pcl 5e
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
Posted on Sep 25, 2010
seeker5211
  • 1089 Answers
SOURCE: i have hp laserjer 2420
The message says that your printer has a bad fuser.
It is going to have to be replaced.
The part number if you are in the states is RM1-1491-000CN
Posted on Feb 02, 2011
Could you please show me the scanner motor for hp laser jet 2420.
Figure 7-14. ECU wiring
1 FM1, main fan motor (J509)
2 Tray 1 pickup solenoid (J508)
3 Tray 1 sensor (J503)
4 Laser/scanner motor (J402)
5 Memory tag reader (J510)
6 Fuser motor (J501)
7 Main motor (J407)
8 Door switch (J408)
9 FM2, sub fan motor (J512)
10 Thermistors, rear-output-bin sensor, delivery sensor (J405)
Jul 03, 2011 | HP LaserJet 2420 Printer
I have hp laserjer 2420 printer, it is not performing printing and display error "50.4 fuser error " what i shall do now ?
Feb 02, 2011 | HP LaserJet 2420 Printer
Hp laser jet 2420 printer 50. error
This is an error with your fuser...you need another fuser...any 50.x error is related to that and they are something that needs replacing regularly(100-150k pages) the heat resister goes out or the film tears..ect....Try www.getthatpart.com for a good deal on a used one...Used are normally just as good as new for a lot less and these guys guarantee their units, they have someone you can call on the phone, so I recommend them. Hope this helps you.
Oct 25, 2010 | HP LaserJet 2420dn Printer
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Thanks
Sep 25, 2010 | HP LaserJet 2420 Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
50.4 fuser error
May 06, 2009 | HP LaserJet 2420 Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Error code
This is a ram dimm error try changing dimm(s) to other slots(s) please ask for more info if required
Oct 31, 2008 | HP LaserJet 2420 Printer
23 people viewed this question
k24674
jasbo
jasbo
