Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Skipping wash cycle
Starts to fill,pauses, skips wash cycle,goes to rinse cycle
    Top Expert:
  • Admiral Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Posted on Jul 14, 2013
3 Suggested Answers
  • 351 Answers
SOURCE: washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Posted on Mar 17, 2008
  • 1531 Answers
SOURCE: washing machine wont quit filling during rinse
if this is a top loading machine. turn it off the pull the drain hose up about six inches but do not remove it from the wall drain you should here water flowing out of the hose once the water has stopped restart you machine with the hose in the sam e position then it should fill up to the proper level and start washing. all this is provided it is not over flowing on the floor.
let me know how things go for and good luck
Posted on Sep 28, 2009
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Jumps wash cycles
If the unit is skipping cycles you will need to replace the timer.Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
AWM1404/4 whirlpool skips wash programmes
try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Mar 19, 2008 | Washing Machines
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
368 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
