Question about Garden
Replace Bearings on wolf cobra elec lawn mower
Have replced the drive enb bearing but don't know how to replace non drive end bearing. how to remove old bearing fom rotor?
  • 24 Answers
SOURCE: replace front wheel bearings
The bearings in your car are pressed into a hub. If the part is available as an assembly, it can be replaced that way. Generally on a front drive car:
Remove wheels and brake calipers
If it is pressed in: remove the rotors, disconnect the drive shafts and remove the steering knuckle. Then the old bearing is pressed out and the new one pressed in with a machine shop press. If the bearing is part of the hub, that will be unbolted and the new one swapped.
On a scale of 1-10 difficulty, Id rate it a strong 7
Posted on Jun 20, 2008
SOURCE: how to replce front wheel bearing bmw 745li 2004
Thats what the mechanics also say "He owns a BMW..... Lets RIP him OFF'!!! dats y we bmw owners like to repair ourselves! who agrees wit me???
Posted on Oct 07, 2008
daves944
  • 1050 Answers
SOURCE: 2003 Pontiac Montana Front Wheel Bearings
Remove the wheel, remove the hub nut, remove the brake caliper and rotor, put your socket and extension through the hub flange onto the bearing retainer bolts, undo them, release the abs sensor connector if it has it, remove the bearing and hub flange as an assembly, put the new one on and go backwards from here. Torque the hub nut to 180 ft/lbs, your done.
Posted on Apr 08, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
Www ehow com
you have a tie rod thats all and thats to alighn wheels if you problem with stering radious look for bad bearings bad tie rod end replace
Sep 02, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet riding mower Mower Blade and shaft wiggle
I am not familiar with Cub Cadet but would suggest that if spindle is loose [wiggles] then one or more bearings need replacing. Remove the whole deck from the machine and turn over. Check the blade [s] are firm. If not undo the nut holding the blade on and remove the spindle and its housing from the deck frame. Remove the driving pulley also. Usually these types of drives have a spindle with a special fitting on the lower end for the blades to fit onto. Some are forged on the end of the spindle and the bearings come off the other end. Others will be removeable and so the bearings will come off each end. What ever, clean up with fuel and replace both bearings. You may have to remove the seals on the inside to let grease in. Make sure the top bearing has plenty of grease as it may miss out if all the grease goes down. Some machines it is better to leave the seals on top bearing. I have found that it does not pay to use the hose connection to clean the deck as the water destroys the bearings and only half cleans the deck. Best to put planks onto trailer or ute deck and run mower up so you can get underneath with big screw driver every now and then. Take blades off and sharpen them then also.
Aug 21, 2014 | Garden
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
L115 42'' deck drive belt breaks after only
Possible spindle bearing. ( mandrel bearings )
Spin blades by hand with deck belt disconnected and mower turned off of course. Listen for grinding noise. If so, Replace mandrels and bearings fully. I would replace all few pulleys.
Not too bad price from the right small engine repair shop such as places like Pats Small Engine in Minnesota. ( which pwns)
Jun 13, 2013 | Garden
Drive belt getting hot and slowing down
check bearings of all spindles the belt drives Find the one that has seized and replace the bearings. They all suffer from water and dirt getting in
May 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
The front end of my 2001 chevy blazer makes a kind of wa, wa,wa sound going down the road I don't know if it is the bearings or brakes or something else
If it's your bearings the sound will go away when you turn around a corner or curve. If it's your brakes then it should get better or worse when breaking.
I'm pretty sure that it's a wheel bearing in your instance. If you do decided to replace the bearing then don't forget to torque the axel nut down to 103 ft. pounds. This is very important.
Too much or too little torque on your nut will cause early failure of your new bearing.
Aug 03, 2011 | 2001 Chevrolet Blazer
My transmission is makeing noise and every time i push in my clutch it goes away i think its my throw out bearing and if so can i drive it to a shop or should i have it towed? and will there be anything...
Yes, you can drive it, as long as you don't force it. At that mileage all the bearings are reaching their end of life, while you are replacing one you should replace them all. Check also the status of the synchro rings.
Jun 10, 2011 | 1999 Ford Mustang Cobra
I have a 19.5 HP Craftsman (Briggs and Stratton) Riding Lawn mower. It has a 6 speed transmission (uses a stick and clutch to shift) I was mowing the lawn and came to a stop and then the mower would no...
I would suspect the issue you are having is the belt. I would raise the front of the tractor not tip it on its side. The belt is pretty straightforward on install.
Mar 30, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
