No picture from blu-ray player to Yamaha HTR 4065 receiver
Receiver TroubleshootingI have a fairly new Yamaha HTR 4065 receiver. It had been working really well for the first 3 months up until a couple of weeks ago when it now doesn't seem to receive the input from my bluray player. Audio comes through fine, but the video does not come at all. I've tried changing cables and a different DVD player without any luck. The satellite Audio and picture work just fine, even in the same input port on the receiver. Any suggestions?
3 Suggested Answers
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
ameliawang93
  • 1001 Answers
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
Posted on Jan 17, 2017
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
I have my HTR 6030 receiver hooked up with a blu ray and am trying to get true 5.1 sound. Have a blu ray disc playing and have put the setting on "straight" on receiver as instructed by future...
If you only have sound from the front left and right speakers when it's set to STRAIGHT, it means the audio source is only 2 channel stereo. As the audio source is from Blu-Ray, the audio should be HD if you are using the correct type of audio cable.
I really need more information from you to give a definitive answer. If you are only using a RCA type audio cable (red/white plugs) from the Blu-Ray to the Yamaha receiver then you will only get left and right front channels on the STRAIGHT setting. This receiver does not have HDMI, so you really need to be using a digital optical audio cable to get true 5.1.
Please can you let me know how the BD player is connected to the Yamaha receiver if you need further assistance.
Thanks,
BElectric
Feb 05, 2011 | Yamaha HTR-6030 Receiver
I have a Yamaha HTR 5450 and tried to hook a blu ray player to it. Only choice I had was the Yellow RCA video and red and white for sound. Could not get video to work but could get sound. My older DVD...
Why is it so important to have BluRay audio on an old TV? Or its video into the Receiver?
What purposes are served with unnecessary 'hops' through electronics that can't use it or improve it?
Get the digitsl audio from the BluRay into the HTR and give the TV the best it can accept for video. Your TV probably has a mid-fi RCA audio input, too. The BlurRay has an output for that, too, if you realy want it.
Jan 22, 2011 | Yamaha HTR-5450 Receiver
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
Remap digital audio on Yamaha HTR-6130
Actually I found in the sound menu on the receiver that there is an input source setting changer for the 3 digital audio inputs. Also you can change the names of the other inputs to match your components needs.
Good work Yamaha.
Jan 11, 2009 | Yamaha HTR-6130 Receiver
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
 Grubhead
Grubhead
