Question about Garden
55min run 323l trimmer
Starts fine, runs,fine for about 5 min will not restart for about 20 to 30 min changed fuel filter changed ignition plug
  • 2,239 Answers
Check the fuel filler cap, there is a breather in the top if this is blocked it will create a vacume in the tank, try leaving the cap loose and see if the problem has gone, if not then this is an ignition unit issue, replace the ignition unit.
Posted on Jul 14, 2013
  • 2692 Answers
SOURCE: chainsaw will run for 5 min then stalls out
Fuel is induced into the engine via the diaphram to the carburator. If the diaphram is weak or has a hole in it, it will run out of gas just like you discribed..
Posted on Jan 18, 2009
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
  • 120 Answers
SOURCE: saw will not stay running
It sounds like it is not getting enough fuel to keep it running. There may be a clogged screen in the carb or dirt somewhere in the carb. Another thing you can check is the adjustment on the carb.
Posted on Jun 19, 2009
SOURCE: Husqvarna 2100 runs for only a few seconds
Hi, I spent most the day yesterday fighting the same problem on my husqvarna 45. My symptoms were that it ran for 2 seconds then died. The spark plug would come out wet, and if I kept cranking the starter, I could see gas coming out the exhaust. Obviously flooding.
It turned out to be the inlet needle valve being stuck open. I replaced the needle valve, still no luck. This is the valve that regulates the gas coming into the carb, normally pushed by a float. Chainsaws use a rubber diaphragm instead of a float because they need to run sideways.
I had a closer look at the cavity the valve fits into (two pairs of reading glasses!) and saw some greenish hard stuff that my carb cleaner spray would not remove. So I took an electrical tye wrap that's width matched the diameter, and rotated it till the crud was gone. A wooden bamboo skewer or toothpick might also work, don't use metal.
Reassembeled, and runs fine. Your carb may be a Zama which has a good technical guide online: TechGuide_2007.pdf. Walbro diagrams might also be online. Good luck.
-Chris
Posted on Aug 29, 2009
Testimonial: "Thanks - I found something similar, slime had worked its way into the carb. All I had to do was take the top off the carb and spray it out."
  • 4088 Answers
SOURCE: husqvarna chainsaw stops when using it
Check for spark after it quits. If none, the ignition module may be dying when hot. If ok, check the muffler for plugging. Use compressed air to remove sawdust from cylinder and head area. If everything looks good, note whether the spark plug is getting wet with fuel after trying to restart the saw. If dry, check the fuel lines for cracking or other deterioration. Make sure the fuel tank vent is clear of debris. (Loosen the fuel cap for a moment, then see if it will start.) Hopefully, one of these suggestions will hit on the problem!
Posted on Feb 20, 2010
Where do I get a new ignition coil for my 323L trimmer
Are you sure its the coil.? Have you tried relesing the fuel cap and trying it again.? Could possibly the fuel tank vent, creating vaccum in the tank and starving the engine.
Jun 28, 2012 | Husqvarna 323L
Mower start fine. Runs for 20 min or so and then runs ruff and shuts down. Restarts fine and shuts down appr. 5 mins later. Has new spark plug,air filter, fuel filter and more than enough gas.
It's one of two things. My first thought is that you have a clogged gas cap. Try loosening it when the mower starts to run ruff. If it smooths out again and runs fine, then you know that the carburetor is not venting properly. Either buy a new gas cap or clear the breathing holes in the cap, if possible.
The only other thing it can be is that your Ignition Coil is going bad. A bad Coil, once it gets hot, will shut down. But it usually takes longer than 5 minutes for them to cool down well enough to start back up.
My Vote is the cap!
Good Luck!
Jim
Aug 18, 2011 | Poulan Garden
Starts well,runs wellfor five mins but then cuts
My first guess would be the fuel filter. It is probably almost completely plugged.
Oct 23, 2009 | 1991 Volkswagen Passat
Husqvarna 323L Line Trimmer - Runs for about 5-10 seconds,
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to seedaylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Husqvarna Garden
96 gmc sierra hard to crank after 12-14 hours
that has a votec engine in it the fuel pressure is droping at knight and it takes 60 psi before the injectors will fire most likely cause fuel pump ,leaking injector ,or a feul pressure regulator
Jul 13, 2009 | GMC Sierra 1500 Cars & Trucks
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
