Copiers
Problem for Copiers
Generic problem for all Copiers
I cann;t Copy or print in paper 81/2 x 14 ...
By bromerom on Mar 29, 2009
in my country the legal paper is 81/2 x 14 and when I put that paper the printer gets stuck, it doesn't work have to open the drwers and get the paper out that's jammed in the printer.
I don;t see how to make this paper to work.
Clarification Request
Posted by belderm on Apr 01, 2009
It works well with regular sizes letter and legal from Usa 81/2x11 and81/2x14
Belderm has describe the problem I want to use 81/2 x13 paper and the printer copier canon ir3100c only works with 81/2 x 14 paper when I try to change the paper sizes it doesn´t accept the size. If I use the paper 81/2x13 it jams in the copier.
Thanks bromerom
Posted by sandmanmac on Mar 30, 2009
what make and model of machine? does the regular size (letter size) feed properly?
Same Problem
Apr 01, 2009
-   the printer copier is Canon IR 3100C, and the tha problem is that the printer doesn´´t have that paper sizes, trhe lager is the legal paper of USA that ´s 81/2 x14 and what I want to use is the 81/2 x 13. Sorry didn´t explain correctly the problem
Thanks benjamin -   belderm
Mar 29, 2009
-   i have some problem to download this drivers Sharp 5320 drivers download-   ifteqar_itu
Solution #1
posted on Mar 31, 2009
Somewhat Helpful)
20YrsCompExp
Rank: Guru
Rating: 86%, 135 votes
Just guessing.... Not knowing the model or Make of the copier. You Probably have to change the papersize on the drawer that you are putting the larger paper into to equal 8.5x14: usually by a dial or the position of the fences (side and rear paper guides inside of the tray)....
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
my mp220 will not scan, it will only print and photo copy
Answer
Error message 45-1 is being display on Konica Copier model 3135
Answer
konica 1216
Answer
konikaminolta1216
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
