Question about Cnet CWA-854 (CWA854) 802.11b/g Wireless Access Point
Firmware cnet cwa 854 - Cnet CWA-854 (CWA854) 802.11b/g Wireless Access Point
SOURCE: CWA-854 as repeater
I couldn't manage to get the CWA-854 to work in repeater mode with WEP encryption enabled, but it is possible to use MAC Access Control even in repeater mode. Just put the CWA-854 in Access Point (AP) mode, add the MAC addresses you wish to allow in the Access Control tab and selecting Allow Listed from the pull-down menu, and then go back to the repeater configuration you posted. In this way, you may not have encryption, but you can still block others from connecting to your wireless network.
Posted on Jun 26, 2008
  • 5 Answers
SOURCE: Can't set up Cnet CWA-854.
Have you tried changing your IP to 192.168.1.3 and see if that makes any difference
Subnet mask 255.255.255.0
Posted on Jun 28, 2009
  • 108 Answers
SOURCE: HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Posted on Jul 08, 2009
  • 72 Answers
SOURCE: the wlan light doesn't flash
Please check the IP address of modem and wireless accesspoint.
Make sure that Both are in same network.
Posted on Jan 04, 2010
charlesharun
  • 174 Answers
SOURCE: How to use cwa-854 other than bridge mode?I would
Two aspects have to be considered to establish a network with brideable functions
1. The computer infrustrure have to be built, for example the computers have to be connected to each other by physcal cables to achieve the first steps the the second steps requiring wireless functionality.
2.The wireless devices like modems transfer signals between the two device to communicate otherwise would have communicated by wire connectivty of cables. The wireless device creates a bridge between the two devices also called an access point located on the computer networking area ( open my computer, click system settings and select networking functionality for any alteration purposes)
3.Once each device in the connection is ready functioning, the access point becomes visible message that could be manipulted by the computer administrator.
4. Clicking on the system networking settings will allow customisable features explanable
a. The network area would have the option of creating passwords to every device for reasons of that each device on the network is a separate entity only possible to achieve connectivey by another device providing wireless capability.
b. manipulate the wireless features that would only be displayed after each gadget on the infrastructure has been phically connected with wires amongs one another and to power supply in which instance to be powered on.
c. the modem once powered on should recognise an available computer physical establishment because wireless chips are embeded in every entity of the setup.
d. The computer display of message about wireless signal recognistion is then manipulated to suit the administrators specifications explanable.
1. A user name and password are established for reasons of contolling access to the connection of several devices
2. The device could function without passwords and username only becomes available to every demander making possible connectivty so several untilities and infructure.
Important notes
1. Your computer set up of networks are a network that when capable of communicating elswhere with additional networks insfrustures together is an internet.
2. Rememer to setup your newkwork properly or esle access could not be made into another network and vise versa.
3. If you set up any passwords and user names in the process of establishing a network,, other persons requiring connectivety woudld requrre what is called Codes in computer temnology to acess the network. whenever the passwors are lost would compromise your acess to the link of wireless signals as well.
Posted on Dec 02, 2010
Buenas noches tengo un acces point cwa-854 y no puedo entrar a la direccion 192.168.1.253. No se si esto es necesario para que funciones por que la verdad despues de haberlo instalado no logro conectarme....
Con el fin de acceder a la direcci?n IP por defecto, tendr? que cambiar temporalmente la direcci?n de arriba de su PC. ┬┐Puedo sugerir 192.168.1.250?
( M?s informaci?n )
In order to access the default IP address, you will need to temporarily change the UP address of your PC. May I suggest 192.168.1.250?
( MORE INFO )
Rough Translation: Good evening I have an access point cwa-854 and I can not enter the address 192.168.1.253. Do not know if this is necessary for functions that the truth after it is installed I fail to connect. Gabriela Best
Dec 18, 2010 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Disconnetion problem
Try to update the router and the access point. Download the latest firmware and then go back into them and then set them up again. It should be pretty simple, just time consuming.
Let me know if this works or not and we can go from there. Good Luck.
Apr 02, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
The wlan light isnot lightind, and i cant configure
Is the power light solid on the router. Try to reset the router for 30 seconds. then unplug the power to the router and plug it back in, Wait for 1 minute and try to reconfigure the router. Click Here for step by step solutions.
Nov 16, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Tried to set a new IP-adress. now I cannot access it
Go back to IP address and set it to obtain automatically.
Sep 26, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
Thanks
Jul 08, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Oct 12, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Configuaring wireless ap
if that is the case there is a possible issue in the firmware of the device (access point) it is either you flash the firmware yourself or better if you report this to CNET because there is a possibility that you are not the only one that is having this kind of problem.
http://www.cnetusa.com/newwebsite/techsupport/firmware.htm
CNET USA Contacts
http://www.cnetusa.com/newwebsite/contactus.htm
i stayed in our session until now, just got it disconnected hehe, anyway feel free to leave a comment on our session or a rating perhaps, so that we will know where to improve more on our service, good luck buddy.
http://www.fixya.com/transcript.aspx?cnvid=26456
-voodoomox
Jul 29, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
I CANT SET A PASSWORD
have you tried setting it up thru the web interface ? 192.168.0.1
Jan 28, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
CWA-854 as repeater
Jan 13, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Cnet CWA-854 (CWA854) 802.11b/g Wireless Access Point Logo
51 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
valuesrespec
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
