Dell Inspiron N4020 Error Code 2000 - 0142
I was doing a system restore to the factory image(I restored it to sell it not because of another issue) and the computer stopped at 59%. I called DELL and did a diagnostic. During the test I got error code 2000 - 0142 Status: 49. Please help!
  • 5,626 Answers
Your have miss listed your problem in the wrong category. This category is for cars and trucks, not computers.
Posted on Jul 13, 2013
Geekman
  • 32281 Answers
SOURCE: D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
bschilz
  • 2049 Answers
SOURCE: Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Posted on Dec 05, 2009
Testimonial: "Thank you for your help. I don't know what you mean about the thumbs up; I just logged into my account for the first time today and rated you..."
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
  • 3940 Answers
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Posted on Jan 27, 2010
Factory reset
after the factory reset has finished
Sep 10, 2012 | Dell Inspiron 1525 Laptop Jet Black
I have a Dell Inspiron Mini Laptop 1012, how do you set it to factory seting?
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Jan 05, 2011 | Dell Inspiron Mini 1012 Netbook...
How do a complete factory restore on dell inspiron 1525 when after f8 it says unable to locate file?
Dell.com supply "rescue disks" as do many sites on the net. I think that is possibly the only way to go.
Errors on the hard drive possibly caused the error in the file system, or the master file table has been corrupted.
Hope it helps.
Jan 02, 2011 | Dell Inspiron 1525 Laptop
All i want to know is HOW DO YOU REBOOT A DELL INSPIRON 1545 TO FACTORY SETTINGS I DON'T HAVE THE MONEY TO TAKE IT IN.
Windows Vista: Dell Factory Image Restore
  1. Turn on the computer. When the Dell logo appears, press several times to access the Vista Advanced Boot Options window.
  2. Select Repair Your Computer.
The System Recovery Options window appears.
  1. Select a keyboard layout and click Next.
  2. To access the recovery options, log on as a local user. To access the command prompt, typeadministrator in the User name field, then click OK.
  3. Click Dell Factory Image Restore.
note.gif NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
  1. Click Next.
Nov 09, 2010 | Dell Inspiron 1545 Notebook
I am trying to restore my computer to original state. Was told to use Ctrl F11. This doesn't to anthing. Help
don't hit ctrl f11 instead hit F8 and then go into Dell Factory Image Restore, that will wipe, format and reinstall all the factory software that's stored on the Recovery Drive.
or reformat your laptop using your cd
Sep 29, 2009 | Dell Inspiron 1501 Notebook
I want to restore my dell laptop to factory settings
you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Mar 25, 2009 | Dell Inspiron 8600 Notebook
Can not getr my dell laptop to system restore
Dell factory is on the D: partion. With Vista power on and immediately start taping on the F8 key and do the system restore or marked Dell factory restore. ON XP system power on > hold the Ctrl key down and tap on the F11 key and same as the instructions above If the system demands for an admin password try just clicking on Enter.. or try your user name and logon.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
