Question about Garden
Toro zero turn mower battery drains
The new battery is completely drained after 3 mows
    Master:
  • 969 Answers
Replace ignition switch.
Posted on May 29, 2014
  • 7 Answers
SOURCE: battery drains with mower key in the off position
how long does it take to drain battery,check to make sure battery is good,no bad cells,hold load after charge,check to make sure electric clutch is not staying engaged with switch off...
Posted on Oct 02, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
rycgl
  • 1545 Answers
SOURCE: The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
Posted on May 15, 2011
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Posted on Nov 11, 2012
Battery losing charge
Sounds like you have defective diode rectifier. this little box when working properly allows your voltage to only go 1 way to charge the battery. if you have used a vehicle to boost the tractor you have damaged the rectifier. because a vehicle running puts out 14.8 volts lawn equipment is 12 volts only you can boost using a vehicle only if it is NOT running
Apr 04, 2014 | Garden
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Battery drain vw
Look at things that drain a battery such as a door not completely closed, cabin light on, radio remaining 'on' etc. Also the igntion key removed at off position versus at a notch before. Nothing else TMK drains the battery.
Dec 08, 2013 | Cars & Trucks
Just put a new battery in scuba and it runs about 30 seconds (completely charged)
1) replace again the batteries by new ones and completely charged.
2) test the charger if if functioning properly, can be faulty, and not charge well the batteries.
3) test the power supplies inside from the scuba, to due some short circuit drain the batteries.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
Battery drains while mowing - after about an hour I cannot engage blades if I stop mowing - I have to charge battery after each mow - Have changed battery thinking that was problem but it still continues...
Charging system on the engine is not charging, either the charging coil under the flywheel is bad, or the regulator is not working, you need to check what voltage/amps is coming out of the system, before doing thsi just check all the battary leeds are tight also the negative battary leed has a good earth at the chassis.
Jul 06, 2012 | Husqvarna 24HP 54" Yard Tractor ()
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Something is draining my battery on 97 buick lab.
POWER DOOR LOCKS / STARTER SOLENOID CONTACTS SHORT /A BAD ALTERNATOR REGULATOR.AC AND HEATER BLOWER RELAY STUCK CLOSE.ALL THESE THING CAN CAUSE BATTERY DRAIN.
Aug 21, 2009 | Ford Focus Cars & Trucks
Battery drain on fuse #3 orange
Did you ever figure this problem out? I am having the same issue! i bought a new battery, new alternator, but my jeep keeps dying! i did the battery draw test, as soon as i pulled the fuse block battery feed out the draw was completely gone. can you please tell me what you did, this has been driving me crazy for over a month!
Jan 18, 2009 | 1998 Jeep Cherokee
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
