Question about Sewing Machines
Singer scholastic sewing machine
My machine locks up going forward. I can manually make it go in reverse but when I go forward it lock up. Help!!
  • Sewing Machines Master
  • 7,365 Answers
It would be a good idea to have the machine serviced at a sewing machine shop, it's possible that a part has broken or may have a timing problem..
Posted on Jul 13, 2013
4 Suggested Answers
  • 136 Answers
SOURCE: I need a manual for a Singer Scholastic Sewing
try order from linssewvac@hotmail.com
Posted on Sep 08, 2009
caroldon
  • 17130 Answers
SOURCE: I have a singer scholastic sewing machine 6510 the
Normally any lubrication is required only when there is a friciton with dirt accumulation . Since the moving parts are set with lubrication it is not necessary to repeat any oiling unless you feel the machine moves with a friction. If so check out on the moving shaft for tiny holes to be fed with oil , just need to doze lightly on the moving parts, bushes and rollers of the main shaft.
Posted on Oct 06, 2011
mountain_cra
  • 86 Answers
SOURCE: sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Posted on Sep 10, 2012
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
Brand new Singer 4423 won't go in reverse ?
Your reverse lever may have become disconnected inside the machine. Return it to the dealer if you don't want to fix it yourself.
Jul 29, 2013 | Singer 4423 Sewing Machine
Free singer sewing machine manuals downloads model 9410
my singer model 9410 will not go forward but will go in reverse
Aug 18, 2010 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
