Question about Radio Communications
Search Fixya..manual for workman hp202s watt meter.
Adjusted mag mount antenna w/a swr meter. When checked it w/the meter on the '06 uniden pc78 elite, ch 40 was a lot higher. Which is correct ?
The coax jumpers between the meter and the radio can change the SWR a little bit. It is very unlikely the the antenna can be that low on 1 and 40. Set it for the lowest on 20 via the radio and as long as you are under a 2 on 1 and 40 then it should be OK.
Oct 10, 2016 | Uniden Radio Communications
Need schematics for Para Dynamics 700 covering electronics to make repairs it stop working.
good meter to bad it stopped working . I have no idea where to find the schematic for this but I'll tell you this , workman has the same meter for around $ 100.00, you may be better off just getting a new one . Good luck serching .
May 28, 2016 | Radio Communications
Where can I get it fixed?
go to Rad Shack and buy a small three way switch and put it in yourself.Is it stuck on the high end or the low? If its the high end you can still get a low reading from it. To have someone fix it may just cost as much as a new meter.So,you might think about getting a new one because you won't find another like it on the market.You can get a dosy 4002 or an astatic 600 but I'm 100% sure there are no 700's .I think workman has a twin to it but thats all I can tell you .
May 27, 2014 | Astatic "700 5,000 Watt Single Window...
Where can I buy Toro Workman 3200 carburetor?
go to Toro commercial service center. They are expencsive. I have the same set up as your workman for fertilizing and spraying. Where are you located? I am in Holland,, Michigan
Dec 12, 2013 | Toro Workman 3200
3300hp how many watts output, what swr/ power meter should be used
That style will get about 60w PEAK.. on older styles.. the newer Mosfets will do about 30-40ish..
Meters, are preference.. most are just RMS styles. and you wont see the Peak reading which is fine. there are alot of meters and brands.. Bird, Dosy, MFJ, Siltronix. they all have pros / cons.
if just want simple workman makes some lower end styles. also para dynamics..
there are some MFJ and other brands that have cross needles that show both power and swr at same time. but they will start in the $60ish range and go up from there.
Oct 24, 2013 | Connex 3300 240-Channels Base CB Radio
Just bought a workman 3000 to 7500 watt cb antenna, ever heard of it?? Im going to hook it up at work monday, got a cobra 29 ltd + or - 30 watt output. 9' coax. the antenna has 8" of swr adjustment... for...
cobra 29 has a 12 watt final, doubt you will be doing 30 watts. 25 if your lucky. Use 18 feet of coax, you will get better broad band.
If the antenna comes with the whip in it already, its been tuned at the factory and you shouldn't change it yet.
If not, half way is okay. It still needs to be tuned on a meter. either the one in the radio or an inline.
Mar 06, 2010 | Cobra 29 LTD CB Radio
Can i wire direct to battery to get more power instead of the fuse panel.Plus i have a comet 200 hooked up and only getting 125 watts whats the prob
comet 200? its a 2 pill. 125 watts seems right. The amp should be run straight to the battery always. you can run the radio, but that will not get you more power although it will help with engine noise in your radio. You could be starving the amp if its not run to the battery, but you won't see much more wattage.
Also your dead key will effect your power output. Should have some where around a 2 watt dead key.
This leads me to my next point.
What kind of meter are you using? if its a cheapo pyramid or workman, it may only read average watts. and it will only show you your dead key. It will not show you audio swing. you need a meter that can read peak watts to see your true swing.
you may be doing more then you see on your meter.
Jan 05, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Need more channels and power
for more power replace the 1969 with mrf455 be sure the pins are inverted big power gain about 50 watts
Feb 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Light for meter on cobra 200
The meter uses a fairly standard 12 volt mini amp, I don't know if Radio Shack carries them anymore, but any decent CB repair shop should have it. Workman Electronics distributes these to dealers, their part number is "CMB".
Aug 06, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Radio Communications Logo
87 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
