Question about Frigidaire 31 in. FEC30S7E Electric Cooktop
Caps come on my cooktop but indicator light wont come on
Indicator light wont work
  • Official Brand Answer
  • 4,342 Answers
Hi George - Thank you for your post! Let's try resetting the cook-top by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control) or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Posted on Jul 17, 2013
Can I get knobs with indicator lights for a dacor cooktop , model#sgm464gg,serial#85464
Here is the breakdown I found for you SGM464GG
I hope this helps you, good luck
Nov 16, 2013 | Cooktops
The gas top stove will not light. Gas is coming out on all 4 burners but it wont light.
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 15, 2011 | Cooktops
GE Profile glass top cooktop- burners do not heat, indicator lights do work
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
Mar 09, 2010 | GE Cooktops
Maytag MEC5430 cooktop burner indicator lights not working
If indicator lights are all that wont work there is a "P" terminal on the surface switches (unless they are controled through a board). The P is for Pilot And 1 side usually the "P" terminal of the switch is allowing the light to recieve the power signal that the element is recieving from the switch. The other side of the pilot light(s) will all be wired together at a "common" pont.
My guess is that if you have individual piolet lights this common point is not tied in to the circut now. 1 wire off or loose and none of the lights work. However it should be simple to trace back to this point and effect repair to it.
Jun 12, 2009 | Maytag MEC5430 Electric Cooktop
My ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Dec 27, 2008 | GE 30 in. JP340 Electric Cooktop
Hot burner indicator light won't shut off
the switch for the bottom right burner is bad but doent not affect the cooking, just the light
Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
Wiring new cooktop
no , wiring at endicator light loose probable or deffective indicator bulb
May 11, 2008 | Frigidaire FEC30C4 Electric Cooktop
Burners won't light
remove hte buerner cap and with a nail file or emory clloth try cleaning the electrode(sparker), sometimes a build up of carbon onthem will prevent proper lighting, also lool for cracks in electrode itself,if ther cracked they wont be very effective and need replacing
Feb 27, 2008 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Frigidaire 31 in. FEC30S7E Electric Cooktop Logo
54 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
