Question about Taco 265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature
Turn off how do I set the clock to turn on and off. It came with the house without any instructions. thanks
    New Friend:
So much confused about it... let me check out.
www.mrosupply.com
Posted on Jul 14, 2013
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    We have just moved in to a new house (not Brand New) and it has a Stoves Premier 900EMa Electric Double Oven. We do not have any manuals and need to know how to to set the clock?? Any assistance would be...
    Without knowledge of the particular clock, try holding the start timer (I->) and duration timer (->I) buttons at the same time, then pressing time advance (+). This should set the clock at 1 minute past 00:01. Good luck
    Dec 09, 2009 | Dryers
    Emerson Clock Radio Model CKS 1855
    Try Googling (emerson)(CKS 1855)(manual) without parens for instructions.
    Sep 01, 2017 | Emerson Smartset Clock Radio
    Pioneer DEH-P500UB set the clock
    1 Press SRC and hold until the unit turns
    off.
    2 Press MULTI-CONTROL and hold until
    CLOCK SET appears in the display.
    3 Turn MULTI-CONTROL to select clock set.
    1 Use MULTI-CONTROL to select
    CLOCK SET.
    2 Press MULTI-CONTROL to display the
    setting mode.
    # Press BACK to return to the previous display.
    3 Press MULTI-CONTROL to select the segment
    of the clock display you wish to set.
    Each time you press MULTI-CONTROL, one
    segment of the clock display is selected.
    Hour—Minute
    As you select segments of the clock display,
    the selected segment blinks.
    4 Turn MULTI-CONTROL to put a clock
    right.
    # You can also perform the same operations by
    pushing MULTI-CONTROL up or down.
    Feb 18, 2009 | Pioneer DEH-P500UB Car CD/ MP3 Player
    How do i set the clock?
    no but if u call zanussi customer care they will send u an instruction booklett number is 08705727727 op 3 hold op 2 op 2
    May 30, 2007 | Zanussi ZHF470 Electric Double Oven
    Taco   265-1 / 563-2 Combination Analog 24 Hour Clock Timer/Temperature Logo
    52 people viewed this question
    Top Taco Hardware & Accessories Experts
    deton8 von Splosion
    Gene Haynes
    Porl K Smith
    Porl K Smith
    Level 1 Expert
    Are you a Taco Hardware and Accessory Expert? Answer questions, earn points and help others
