Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Code 91 on model 8111 intex salt water system
[salt level at 3000. electrolytic cell soaked & cleaned repeatedly. ph at 7.5 unit still coding 91] new unit is one season old (stored over winter) 8110 unit fixed with with adjustment "under-the-hood" discovered online and currently in service. no adjustments possible inside control box on 8111 unit. Any solution similar to 8110 model available?
  • 297 Answers
SOURCE: Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Posted on Jul 13, 2009
  • 8404 Answers
SOURCE: I have added 40# pool salt to our Intex 52
Can you clean your sells? Give that a try ... dont over salt your pool.
If you still have a question, consult your pool supplier. They are nice people.
Posted on Jun 05, 2010
  • 297 Answers
SOURCE: Intex salt water chlorinator 56602
First of all 91 is low salt content not too much
Are you checking your salt level with a test strip
You need to be at 3000ppm anything under 2800ppm can trigger an alarm and not produce enough chlorine.
Same thing if you are over 3600ppm
all manuals just give you an amount to start with but it is up to you to fine tune it
After adjustments you need to filter only for 24 hours before trying to generate chlorine
Posted on Jun 27, 2010
  • 8404 Answers
SOURCE: Intex Deluxe Saltwater System & Filter Pump
Do you have 3200 ppm salt in your pool? Have your pool supply place check it for you.
Posted on Jul 24, 2010
  • 297 Answers
SOURCE: constant code 91! after only 1 week my first
A few things to do or you will create your own problems.
First and for most you must filter for at least 12 hours after adding salt to distribute the salt completly
You can not just blindly ad salt like you said you added a bag.
Although the manuals have an amount of salt for different size pools it is just a starting point. It is up to you tp fine tune
you must get a salt test kit
the kind that reads #'s not color
Get your salt as close to 3000ppm as possible
any lower than 2700 and you will get a low salt alarm and you will also not be producing enough chlorine
any higher than 3500 and you can go cloudy, trigger high alarm, and the water will taste nasty
you can even trigger low salt with too much salt content
So remember 3000ppm
If you are higher than the 3500 then drain 20% water and fill with fresh
continue this until you get to close to 3000
If low follow directions for low salt either on the test directions or bag of salt
I have had my system for this being the 4th season and have never cleaned the cells
any way, when you get the pool to around 3000 filter only for about 12 hours then turn on your generator
It should work fine
Posted on Aug 02, 2010
Testimonial: "thanks so much for your input-you're quite right about blindly putting in salt. i will do asyou suggest"
Why do i continue to show low salt?
I do have the same problem every few days all I just discover is that I remove the cell tube and with the help of a long thin knife I clean the surface of the copper cell both in between and outsides. There is always dry salt on the surfaces and after the cleaning the sensor reading is in acceptable level so the chlorinator is working perfect without any 91 massage. To work it every day in order to avoid this happens very often and of course every time you hear the beap sound you have to repeat the scrutching and cleaning with the nife,
Jun 13, 2014 | Intex Automatic Salt Water System for ...
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
What is code 91 on intex 8110 model
This is the code for "Low Salt"... Could mean two things
  1. Low Salt and will need to test ppm and add to target 3000ppm
  2. Dirty electrolytic cell, soak with vinegar and flush clean..
Hope this helps!
Aug 20, 2011 | Intex Automatic Salt Water System for ...
I have added salt due to constant low salt warning. I have been brushing and running pump. It appears to be on a 6 hr cycle as 06 shows up when turned on. It also goes into sleep mode. Test strips show...
Way too high on the salt.. about 5000 to 7000 ppm. You should be around 2000 to 3000 ppm or 5.6 to 6.6... I had the same issue with my system and it's always the cell..Look inside the cell and if you can see white stuff inside, it needs to to be cleaned... The manual states to soak with vinegar for 6hrs.. I soak mine for 24, flush and soak again for 6hrs and flush again.. Comes our clean.. and the low salt alarm goes away until the next time the cell gets dirty with the white buildup... You can add an additive made by hth called "Cell Saver"..Prolongs the cleaning cycle... After you clean the cell and your filter, change your chlorinator cycle to 10 hrs with your pump to run 11 to12 until the pool clears and then lower to maintain the proper chlorine level.. Good luck and hopes this works for you.....
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Getting a code 91 LOW SALT. We have had our pool since June. Took a sample to the local pool shop for them to diagnose and my salt was at 4200ppm. It is still triggering low salt....any suggestions?
Usally if the salt level is above 2000 ppm, it's the electrolytic cell. Did you look inside and verified it did not have any white flaky buildup on the plates??? Do the following if you haven't already and see if the low salt alarm goes away..
  1. Remove the cell unit and cap one end...
  2. Fill the unit with white vinegar and let soak for 24 hrs...
  3. Flush with pressure nozzle until clean.. ( If you can still see some white stuff on the cell plates, soak for and additional 6hrs and flush again)
  4. Re- assemble and set your cycle according to your chlorine level...
Hope this works for you!!!
Aug 11, 2011 | Intex Automatic Salt Water System for ...
When i change the pump filter let run for a while code 92 sets
2 reasons for this code...
1st... High salt level... You must check and should be between 2500 to 3000 PPM.. If higher, drain some water and fill with fresh water and re-check..
2nd... If salt level is okay, your electrolytic cell may have calcium buildup and must be cleaned and flushed.. Cap one end of the cell and fill with vinegar and soak for 6hrs+. Flush with water pressure until blades inside are clean and free of the "White Flaky" stuff...
Hope this helps you???
Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
I added three bags of salt and let it dissolve and still get 91 everytime I try to start the salt water system
Have you checked the electrolytic cells? If any white calcium present, you will need to clean with vinegar..See you manual on how to soak...
Please rate if helpful
Jul 24, 2011 | Intex Automatic Salt Water System for ...
How to stop it frfom beeping/flashing 91 low salt.
1st... Check electrolytic cell and clean with vinegar...If white scalley stuff inside, cap one end and soak for 6 to 12 hrs and rinse until clean
2nd...check salt level, see manual for PPM, if low, add salt.. If you have a big pool 12000 to 15000 gallons, you will have to add up to 100 lbs of salt..
3rd... Run only pump for 24 hrs to dissolve salt..
4th... Set you cycle and should be fine
Hope this helps and rate if it does
Jul 16, 2011 | Intex Automatic Salt Water System for ...
Constant code 91! after only 1 week my first chlorinator was replaced due to this code. Have been using my replacement for approx 2.5 weeks and got my first code 91 - added 1 bag of high purity pool salt...
So remember 3000ppm
It should work fine
Aug 01, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
18 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
