Question about Sharp EL-6990
Factory reset Unable to access information
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Factory reset clears EVERYTHING and brings it back to how it was when you first got it. You could try contacting Sharp to see if there is a way to restore your data but it is most likely gone for good
Posted on Jul 13, 2013
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Access password
Hold the reset for 60 seconds, you should have a factory setting. Google the password for the factory setting.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_573a00ba7e399076
Dec 05, 2011 | Computers & Internet
TOO MANY PATTERN ATTEMPTS, GOOGLE PASSWORD UNKNOW, NEED MASTER RESET
Hello, tealey.
Unfortunately, there is no way to reset the pattern unlock without knowing your google account login information. To attempt to recover your google password:
1) Go to www.google.com, 2) Click on "Sign In" in the upper right corner, 3) Click on the "Can't access account?" link on the right side underneath the username and password fields.
If this works, great! Enter your recovered information and then you will be prompted to create a new unlock pattern.
If you are unable to recover your account information, you will need to do a factory reset on your phone. Sadly, because you didn't provide the make and model of your phone, I can't tell you how to do this, but a quick google search should be able to point you in the right direction.
Best of luck!
~Q
May 04, 2011 | Cell Phones
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
Wireless device problem
For virtually any router, wireless access point, or modem, you will find a tiny round hole just big enough for an unbent paper clip to be inserted. The word reset may be next to that hole, but not always.
Pushing the unbent paperclip into that hole firmly for 10 to 30 seconds will reset the device to the original factory settings.
If you have the quick-start guide or manual for the device, you can use that to set it up. If not, visit the web page for the company and look for tech-support or downloads to find the manual for that particular device. You can also Google the actual device and part number information along with the words 'manual' or 'setup' and find the page that way.
Sep 05, 2017 | Intel PRO/Wireless 2011B LAN Enterprise...
Unable to access some menu options
maybe if you go to parental control and type in the code to unlock the v-chip , all other will unlock as well.
Aug 16, 2008 | Samsung HLP5085W 50" Rear Projection...
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Sharp EL-6990 Logo
223 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
