Question about Dryers
Whirlpool cabrio dryer has water in it. Lent filter is also wet. Last time used was over a week ago. Why? Have had dryer for over a year and never have i encountered this problem with this dryer or any before.
    Top Expert:
  • 12,223 Answers
This happen with the dryer A typical 12-pound load of laundry weighs about 20 pounds when it emerges from the washer, meaning that a dryer has to dispose of about a gallon of water with every load. Because of the moisture, exhausting the dryer to the outside is recommended since indoor exhausting can cause mildew and other problems.
Typical ventilation is recomend see the diagram .God bless youwhirlpool cabrio dryer has water in it. Lent filte - 56ed11ca-7868-4b1a-955e-88eafd615327.gif
Posted on Jul 13, 2013
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
SOURCE: Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Posted on Aug 02, 2010
I have asked this question 3 times! my whirlpool washer dryer, Model WET 3399XQO needs to be cleaned under the dryer vent. How do I get to it?
normally...one could take the whole dryer apart its..fairly easily put back together but at the same time you maybe able to clear all the lent out of the dryer even out of th heating element as well....done this before with a dryer that had an issue with the rollers being ruined...
Jan 06, 2017 | Whirlpool Dryers
Dryer beeps every few seconds before the load is done drying
You timmer is going bad most like you need a new timer
Jan 14, 2012 | Whirlpool duet Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Lent seems to be going all over the house. The lent is very fine almost like dust. The discharge vent pipe is not leaking.
when was the last time you cleaned out the dryer?you need to clean out the duct that the lint filter slides into,remove the vent line from the back,if it's a long run blow it out with a leaf blower to clean it out,before you blow it go outside and make sure the duct where the flapper is isn't blocked with anything,and then vac out the inside of dryer where the motor is,you should do this once a year so the dryer works properly and your clothes will dry on time
Mar 19, 2010 | Whirlpool LER4634J Electric Dryer
I have a Wirlpool cabrio dryer in it's "time remaining" says "AF" the clothes aren't drying. and the lent trap is collecting lint on the wrong side
This is an Air Flow warning error and you should check that the filter is clean and free of lint etc. Make sure it goes back in place correctly. Also check that the vent hose is not kinked or twisted or obstructed and any outside flap is opening correctly. It is well worth taking the outside flap or taking off the vent hose altogether and making sure it is clear of lint, fibres etc and this will cause the AF error.
Oct 06, 2009 | Whirlpool Dryers
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Duet Electric Dryer
make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Feb 17, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
