Poulan prolink pp335
Attachments will not go all the way in to lock position into motor end
    Genius:
  • 1,479 Answers
The poulan prolink is a strimmer, not a pc graphics card, please post in the correct section.
Posted on Jul 19, 2013
How do I fix
I am guessing if you are talking about attachments than you are not talking about washing machines. If you look up the make and model of your broken unit on the internet followed by "replacement parts" you should pull up some options for getting what you need.
Feb 10, 2016 | Washing Machines
Why don't windshield wipers return to park position?
Park position switch-sensor is malfunctioning. Fix it or replace the wiper motor with all attachments.
Feb 06, 2016 | 2002 Chrysler Sebring
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I have a Poulan 810EPT electric motor that has worked great but now my attachments won't slip and lock into the end of the shaft. Can't see any obstruction except maybe the flexible cable on the...
This sounds like the flexible drive shaft inside of the main shaft has a stripped ferrule. In order for you to fix this, you will have to take the main shaft off of the motor housing and pull the flexible shaft out of the inside. The replacement part number is 530056570 and should be about $12 to replace. Call the number on the unit to order replacement parts or go to your local sears.
Aug 27, 2011 | Poulan Garden
My Hoover nanolite bagless vacuum has no suction.
12/14/2013 ... just fixed my loss of suction on my Nano Lite by making sure the hose was in the locked position (top of unit where hose does not come off for attachments, look for locked and unlocked symbols - make sure in locked position.
May 22, 2011 | Hoover Vacuums
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Power door locks inop
Sounds like the motor's fried. Its notorious on these cars (I have one).
What ends up happening is the whole mechanism gets gummed up over time and makes the motor work harder just to actuate the "arms" that lock/unlock the door. Over time, eventually the motor burns out, or doesnt provide enough juice to move the arms any more.
The door lock assembly is pretty expensive from the dealer...if you can source a good used one, and lube any moving parts nicely, then it should last.
If you wanna tackle this yourself, here's a writeup showing how.
http://www.dsmtuners.com/forums/articles-electrical-wiring/197793-installing-new-power-door-lock-motor-2g.html
May 05, 2009 | 1998 Mitsubishi Eclipse
Jane powertrack 360
There should be two black triangular attachments with little red handles that go on to the sides of the buggy. You use the grey handles at the end of the side arm of the buggy to pull the rear locking pins backwards and then slot the attachments on to the front pin with the red handle pointing forwards. Release the grey handle and it will lock into place. When both sides are in place, simply drop the car seat on to top of the two attachments. Removal of the car seat is by using the red handles.
HTH..
Nov 10, 2008 | Jane Powertwin Jogger
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
