Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Steam Vac model: F7425-900
It is working just fine with the exception of the brushes not rotating. I removed the filter screen, cleaned it with no result. What can I do to correct the problem?
  • 5 more comments
  • wendyn Jan 13, 2008
    How hard is it to install Turbine ourselves? I can't seem to find a parts manual to guide us during installation.
  • slimbrad Feb 28, 2008
    brushes dont spin
  • chanler08 Jul 01, 2008
    spinners are not roating
    i've cleaned it and stilll no result
  • beckmark Jul 02, 2008
    brushes do not rotate
  • Anonymous Jul 02, 2008
    Brushes quit rotating..I replaced the brushes and cleaned the filter but still no resolution. Is the turbine expensive? Where would I buy it locally in jax florida? Thanks!
  • Anonymous Jul 05, 2008
    spinscrub brushes not rotating
  • brikar Aug 01, 2008
    brushes don't rotate
I had the same problem 2 weeks ago.I took apart the turbine and found that there are two bearings that hold the main gear that were rusted fast. I put some 3in1 oil on them and kept on trying to break them free by turning them,it worked great. Just keep putting oil on and turn them. It beats buying a new turbine! Just pay attention on how you took it apart. Its not to complicated. Good luck!
Posted on Aug 03, 2008
    President:
  • 1,673 Answers
The turbine has probably gone bad and will have to be replaced. That is what drives the brushs.
Posted on Jan 10, 2008
How to remove brushes on a hoover f5887-900 steam vac
Take off both tanks, then turn the steam vac over. Using both hands, pull evenly on each end of the brush block. They will pull straight out. But usually it isn't necessary to remove the brushes. Usually the problem is a blocked screen.If you look at the vac from the front of it with it turned right side up, there is a little window. Pull that off and using your fingernail, clean off the lint. If your model doesn't have a window that you can access, look underneath, near the brushes for a red plastic frame, pull down and it will expose the screen. Hope this helps.
Aug 18, 2014 | Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
Brushes don't turn
I Had the same problem, The brushes are operated by water pressure. Under the machine were the brushes are is a white peice of plastic pull this out and try cleaning the screen. I found this when I removed the cover and lubricated the gears at the brushes, If that does nto work you will have to remove the turbines and lubricate.
Dec 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I have a hoover steam vac deluxe and the brushes rotate very slowly and have little power. i have cleaned the indicator screen.
Check to make sure that the foam filter inside the recovery tank lid has at least a 1/4 inch gap from the top. Other then that, the turbine is what turns the brushes, either the shaft on the top of he brush block broke off, or the turbine is stuck. Sometimes you can take th turbine apart and clean out the components, must times it is better to just replace it rather then mess with it.
May 15, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
236 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
