Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
Can't start chainsaw
Tried to adjust carburator but it won't start
  • 1 more comment
  • Walter Schoustal Jul 15, 2013
    My Manual says turn the Air mix screw all the way clockwise tha anticlockwise 4.5 turnsI tried thr L and H screw about halve way my friend got it started, but I could not, can't pull hard enough
    Air mix screw is the one labeld T ? Because the other 2setsrews only turn halve a turn that's all
    Thanks Randy I will try your Advice
    Sergeant:
  • 391 Answers
Walter:
gently run the fuel and air mixture screws on the carburetor all the way closed (clockwise).then turn them out one and a quarter turns each. That setting should allow the saw to start if you are getting fuel to the carburetor. Once the saw starts, make fine adjustments to the fuel/air mixture screws until the saw runs to your satisfaction.
Posted on Jul 14, 2013
How to adjust carburator on 42cc poulan chainsaw engine?
One full turn out on low and high side for the initial start after rebuild.
Sep 03, 2014 | Poulan Garden
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
I have a p28 pioneer, hasnot been used in a few years. I put a new carburator kit in it, now it's over fueling. Gas is coming out of exaust. won't start. It does fire though.
You need to do a pressure test on the carb, this will tell you if the inlet needle is leaking, it is also important that the metering lever onto the needle is not set too high, on the metering side of the carb the gasket goes against the carb body first to act as a spacer to the metering diaphram.
Dec 12, 2012 | Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
I have a stink 032av spits gas out.carborater And won't fire I tried starting fluid in the cylinder and it still spit out of carborater
Do the easy stuff first: Rebuild the carbuerator... If the diaphram of the fuel pump has deteriorated or has a hole this will cause the problem. One side of the diaphram connects to the crankcase getting pressure pulses that drive this fuel pump diaphram. More than this you wil probably have to take it in for service. The carburator kits usually run around $20. Be careful to not lose parts and assemble exactly the same. AVOID adjusting the idle screws.
May 13, 2012 | Garden
When I stored my pioneer chain saw last year, I forgot to empty the fuel from the tank and the carburator. Now it won't start. What should I do? Louis
GO TO YOUR LOCAL RURAL KING AND PURCHASE SOME ..."LUCAS GAS TREATMENT FOR CHAINSAWS"... TO CLEAN THE STALE GAS IN YOUR CHAINSAW.
HOPE THIS HELPS!
Sep 06, 2011 | Homelite Garden
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro Trimmer. I don't think its getting fuel. It won't start for nothing. Can you tell me about the carburator, or some other problem? Thank you. I also need a new owner's...
http://www.poulanpro.com/node7962.aspx
GO TO THE ABOVE ADDRESS YOU WILL FIND WHAT YOU ARE LOOKING FOR.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Poulan Garden
Chainsaw runs full speed, will not idle. tried to adjust no affect Homelite UT10516
It is most likely the diaphragm needs replacing. This is the cheapest and easiest thing to try first. If this doesn't it may require a new carburator, or you may can rebuild the carburator with a kit. The kits are very inexpensive.
Mar 22, 2010 | Garden
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
150 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
