Kenmore elite oasis ul,f1,f68
Error code f68 appear when running self test error code f 1 appears durring fill cycle. and ul code appears durring drain. with no load in machine. unit already has been completly disassembled and inspected and cleaned. main computer was replaced by sears 3 years ago <1 week after purchased> questiong if suspension rods are like cabrio and causing ul. also noticed minor water inside inner tub required drilling to drain.
3 Suggested Answers
  • 15935 Answers
SOURCE: water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 15935 Answers
SOURCE: kenmore elite oasis washer has error code f1
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
How do you solve the balance problem in the kenmore elite oasis even with no clothes it in
Try running with no clothes? If still shows UL when empty running, your machine needs service. P.S. use HE detergent or else.
Aug 27, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes '
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Mar 18, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
