Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
Chainsaw Did start when cold, won't when hot,tried to adjust the carborator as it says in tnhr manual, turn the l and h set screw counter clock wise and thr T screw 4.5 turns counterclockwise back but have no luck
    New Friend:
  • 22 Answers
Most likely the reason for the failure to start when hot is worn piston rings. Do you have small amounts of oil coming out the exhaust? That's a good sign of worn rings. If qualified, replace your rings and bore out your piston sleeve. You'll be running like new and no more having to wait until it cools to finish the job.
Posted on Apr 28, 2014
    Problem Solver:
  • 7 Answers
Walter the above is a good answer, however often time people are dealing with older chainsaws, older saws that might not have good venting on the fuel tank... When hot unscrew the gas cap, see if there is pressure in the tank or the gas is boiling. That would have been my first answer. Walter what was the problem did you ever solve it?
Posted on Mar 25, 2015
Changed carb on a stihl 025 from a single set screw to a double set screw . what settings do i need to start initially
on the needle setting closest to engine(air) it is turn clockwise till it stops, then open it up counter clockwise 1 turn. The second adjustment needle, should be turned clockwise till it stops, then opened up 1 1/2 turns. Adjust the second or gas, until your engine sounds like it is running it's best.
Dec 06, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
What us the 'H' and 'L' on my chainsaw and how does it work
There are 3 screws on the carb the idle screw usually marked with a T or an I, this screw contacts the throttle spindle and opens it to increase the idle speed, the L screw is a fuel screw, so by screwing it out ( anti clockwise ) will increse the fuel flow through the carb, the screw will adjust the idling, and acceleration up to half throttle, the H screw is also a fuel screw, this will adjust from half throttle to maximum revs, the max revs should be set with a tacometer to the manufacturers fast no load speed, small amounts of movment on boyh screws will make a big difference.
Dec 08, 2012 | McCulloch Chainsaw Shop Repair Manuals 121...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
The carborator iss not adjusted
The idle screw is in the hole right above the primer bulb. Turn clockwise to increase idle. Adjust in small increments.
May 08, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw bar
If this is a tooless adjuster, or the side adjuster, then the small gears in the adjuster system have worn and are now slipping.
Feb 21, 2012 | Husqvarna Garden
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What are the basic carb setting for a homelite ht21 classic hedge trimmer?
As a general rule, it's always best to start at 1 1/2 turns for each adjusting screw. Screw them all the way in, turning them clockwise until snug. Then back them both out counter-clockwise 1 1/2 turns. This will get you in the ball park. You should first, adjust the High screw, 1/4 turn(s) in or out, as needed. After you have adjusted the H screw, then adjust the Low screw in the same manner.
Good Luck!
Jim
Aug 03, 2011 | Homelite Garden
How do you adjust the carborator
If this is a late model saw, the adjustment screws have 'D' heads that need a dealer-only 'D' screwdriver. If the screws have slotted heads, then turn both screws CW to stops (lightly), then back each 1-1/2 turns CCW. This is a basic setting, so the engine should start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine speeds up, but still 4-stroking. When properly adjusted, the engine should 4-stroke, but immediately 2-stroke when cutting. Allow to idle and adjust L CW for fairly smooth running, yet allow the engine to 'follow the throttle'. Adjust idle speed screw to stop the chain from turning, yet the engine keeps running. Hope this helps!
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
117 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
