How to I set the car carborator on my chainsaw craftsman 358.350080
    Problem Solver:
  • 5 Answers
I must assume you have already disassembled the carburetor and cleaned it and installed a carburetor repair kit. If you have not then it will likely be necessary before adjusting the high speed, low speed needle valves and the idle speed screw. Generally speaking you will need to close both high and low speed needle valves by turning them both clockwise until you feel them bottoming out after cleaning and installing a carburetor repair kit. _NOTE: Do not apply a lot of torque when they bottom out or you could cause damage to the needle valves or seat. From the closed position start by opening/turning the needle valve counterclockwise (CCW) 1 and 1/4 turns open. Turning the needle valve in the counterclockwise (CCW) direction richens the fuel mixture and CW will make it leaner. Once it starts and warms up you will likely need to fine tune it by holding the throttle wide open and adjust the (H) high speed needle valve/jet until the engine it runs smooth.
If you do not feel confident repairing this problem yourself, then you can have it repaired by a Sears technician. Here is a link that will provide the nearest drop-off locations: Sears Home Services .
Posted on Jul 14, 2013
  • 1 more comment
  • Walter Schoustal Jul 14, 2013
    High and low speed valve only turn a quater of an inch either way, in my manual it says to turn them all the way counter clock wise and the screw labeld
    T to turn all the way clockwise than counterclockwise 4and one halve turn
    ,I will try your recommendation,
Where can I get a new trigger for my craft an electric chain saw?
Are you sure it isn't a 'CRAFTSMAN' chain saw?
Google
make model spares
Craftsman Chainsaw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-chainsaw-parts-c-158286_172209.html
Fix your Craftsman Chainsaw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
Gas Chainsaw Parts ' Sears
parts.sears.ca/parts/lawn-equipment/gas-chainsaw-parts Are you looking for top quality components that could help get your chainsaw working again? You can rely on the skilled parts specialists at Sears to provide you ...
Craftsman Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b317/Craftsman-Chainsaw-Parts Looking for parts for your Craftsman Chainsaw? RepairClinic.com has the appliance parts, lawn equipment parts and heating/cooling parts you need!
Google
Jun 04, 2017 | Electric Garden
Rebuilt carborator on craftsman wead eater but not passing fuel to spark plug
strimmer carbs are notoriously fiddly and difficult to set up correctly,the needle valve arm needs to be set to correct height.Have you replaced the diapragms??
Mar 08, 2015 | Craftsman Garden
Choke on carborator is broke
You car always remove the air filter and use your hand trick. meter the air coming in to the carb with you hand to get it started.(Less air hence "choke")
Nov 06, 2013 | Craftsman Sears Snow Thrower Manual Model...
Chainsaw
Most likely the reason for the failure to start when hot is worn piston rings. Do you have small amounts of oil coming out the exhaust? That's a good sign of worn rings. If qualified, replace your rings and bore out your piston sleeve. You'll be running like new and no more having to wait until it cools to finish the job.
Jul 13, 2013 | Craftsman sears 18" Chain Saw Chain (...
The carborator iss not adjusted
The idle screw is in the hole right above the primer bulb. Turn clockwise to increase idle. Adjust in small increments.
May 08, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you adjust the carborator on a 2.5 stihl chainsaw?
Most Stihl carburetors built after 2000 have limiter caps that prevent much adjusting. the standard for adjustable carburetors is 1 turn out on both high and low then set rpm of idle and high end to specs.
If you need to adjust the engine to get it running there is a problem somewhere else in the systems.
see a dealer like www.arcolawn.com for help.
good luck
Nov 07, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Displaced carborator spring-mower starts but immediately chokes off
Connect the spring to governor arm. It should be very lose
Jim
May 30, 2009 | Craftsman Garden
What tool to use to adjust a chain saw carborator?
generally you should take it to a repair shop, as recommended in the manual. Those settings are set by mfr. Usually also, if you can get to them, use a screwdriver.
Apr 19, 2009 | Bosch Garden
Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
Dec 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Computers & Internet Logo
David Payne
David Payne
