Question about Behringer cx2310 super-x pro crossover 2-way/3-way
Behringer cx2300 whats the best frequency setting on a behringer crossover
    Top Expert:
  • 12,223 Answers
Follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Posted on Jul 13, 2013
  • 1 more comment
  • richard goucher Jul 14, 2013
    We have. Done all that now we need the setting so we can get the right sound mix
  • ernesto cuadra
    ernesto cuadra Jul 14, 2013
    enter the receiver menu setup and proceed with this steps Look at the speaker's specification sheet while in the receiver's menu. Make note of the lowest frequency listed in the "response" section. This is typically 32, 40 or 55Hz. 4 Observe the options available in the receiver's crossover adjustment menu. Take the lowest frequency listed in the speaker's specification sheet and double the value. If the value is 40Hz, the crossover point should be 80Hz in the receiver's menu. This will account for the typical behavior of a 12db/octave high-pass crossover, found in nearly all receivers. High-pass crossover points mark the frequency where, if we assume the use of a bookshelf speaker and sub-woofer, the bookshelf speaker begins to taper off. The low-pass crossover point is where the subwoofer begins to taper in the opposite direction, so that it does not play much mid-range. As a result, response will be flat from the crossover point down to the speaker's natural roll-off. The "roll-off" is the point slightly below the speaker's published lowest frequency where the speaker ceases to produce sound. For example, if a speaker's lowest frequency rating is 40Hz, most likely the roll-off is around 32Hz. This works for tweeters as well. Most speakers roll off at the top end around 22kHz, beyond the point most humans can hear.
  • ernesto cuadra
    ernesto cuadra Jul 15, 2013
    o.k
I have a Behringer nu4-6000 amp that I am trying to connect Peavey 215 speakers (2-1/4 inputs). How do you connect the 4-pole cable that is bi-amping from d Behringer speakon, 1/4 only uses 2 cables.
I can't give you a definite answer but I suspect the Peavey speakers with their four wires require a different sort of amplifier.to the conventional type.
You will be aware in lots of speaker enclosures are one or two drive units and a tweeter. Ensuring the right frequency of signal goes to the right speaker will be a filter or crossover which is also housed in the enclosure. This has been the common way to deliver a good sound forever.
There has been a fashion for delivering a good sound differently by placing the filter network or crossover in the pre-amp stages and then delivering the different frequency signals to two, three or more power amplifiers, each one designed to amplify a particular frequency range and in this way fewer compromises are made to the purity of the resulting sound. Each amplifier would have an output through a pair of wires destined for the drive unit is was designed for.
Two and three rack amplifiers have been a very popular way of delivering sound in cinemas, in particular a powerful bass. I haven't personally been involved with such an amplifier but I remember the magazine Wireless World publishing a series of articles about the system and the instructions for building one.
These are just my thoughts on the matter and your next step would be to examine the internal wiring of your speakers to be sure.
Mar 13, 2016 | Behringer Music
How do i connect subwoofer to pmp6000
Use the "mono out" on PMP6000 to connect a subwoofer. Also turn on the "sub filter" on pmp6000 and set the sub frequency you want.
Jun 02, 2012 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Hi Folks, I have the Behringer PMP3000 Europower Desk. now also have a studiomaster VPX15 Sub (Active 600W). Does anyone know what the crossover arrangements are on the PMP for the Mono out, and what...
There is no crossover arrangement. On the PMP5000 they have a tunable filter INTENDED to do low pass for a subwoofer. When selecting this mode for a subwoofer The frequency of the low pass filter can be set between 30 and 200 Hz. This feature is NOT available on the PMP3000.
There is nothing related to a crossover in these amps other than what is mentioned above.
The MONO out is merely an analog summation of both the L and R channels.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Crossover to Es 100 to JBL 8400P. I have Harmon kardon 460 reciver?
setting Crossover frequency is trying to find the best frequency where the sub will see below that frequency and the es100 will see above that set frequency for maximum speaker efficiency.
8400P, i believe has a adjustable crossover frequency or cut frequency from 50-150Hz.
The e100 has a rated frequency response of 32Hz to 40kHz. So, the lows going to the sub, will allow the es100 to not have to handle deep bass frequencies.
So, I would suggest starting at 100Hz. That would mean your sub will be seeing roughly 100Hz and down, and the es100 will see roughly 100Hz and up.
Listen to your favorite music, and adjust accordingly.
Apr 05, 2010 | JBL Studio L 8400P Subwoofer
Low pass crossover
Low-pass crossover
Both sets of inputs sum the left and right channels together and the
resulting signal is passed through an adjustable low-pass crossover before
being amplified. The crossover control allows you to adjust the upper limit
of the subwoofer's frequency response from 40 to 120 Hz. The subwoofer's
response will begin rolling off above the frequency you set this control to.
You should set the crossover frequency to obtain a smooth and seamless
transition from the subwoofer to the main speakers in your system. If your
main speakers are smaller units with limited low frequency output, you
may wish to choose a higher frequency (such as 100-120Hz) than you
would with larger speakers which have greater low frequency output. With
larger speakers, you might start with this control set lower, such as 80Hz.
Jan 05, 2009 | Velodyne CHT-10 Subwoofer
Crossover?
A crossover is a circuit that breaks down a whole spectrum of frequencies into groups. For example, your speaker has 3 individual speakers (drivers) in it. There is a woofer, mid and tweeter. A crossover will send the appropriate frequencies to each of the drivers. The woofer can not reproduce high frequencies so it doesn't make sense to send them there. The sam can be said for low frequencies and the tweeter. The crossover point defines the splitting point of the frequencies. Depending upon what sub-woofer you are using usually the crossover freqwuency is either 80 or 100. Most often it is 100.
Hope this helps,
Dan
Aug 20, 2008 | Onkyo TX-SR503 Receiver
How to adjust
hello . i think i can help ...u want to set your crossover points to 125Hz and for the subs if u want deep bass set them to 50 to 80Hz...try them and see what u like best
Jun 20, 2008 | Sony XM-2200GTX Car Audio Amplifier
Feedbacks
it is best to use the feed back detection switch of your eq.,
Apr 25, 2008 | Behringer FBQ6200 Home Equalizer
Behringer cx2310 super-x pro crossover 2-way/3-way Logo
205 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
