Question about Lands Phones
Panasonic cid caller manual kx-tsc8spw - Lands Phones
CORDLESSGURU
  • 106 Answers
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Posted on Feb 19, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
  • 30 Answers
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
Posted on Feb 21, 2009
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep.  Repeat if you want mute again.
Jack
Posted on Feb 22, 2009
SOURCE: panasonic kx-tg6051b instruction manual
http://service.us.panasonic.com/OPERMANPDF/KXTG6021.PDF
Posted on Jun 02, 2009
How can i set my Panasonic phone-extension to see caller ID
Let's see. Panasonic made 4 or 5 6x16 phone systems, and the ones that had CID required a card ending in part number -93. That and programming and CID service from the telco and you can have Caller Id.
Carl
Jul 17, 2012 | Panasonic KX-T7730 Corded Phone
We have a panasonic KX T7735 phone system at home and I'd like to know how to set up caller ID for this system
You need 3 items, CID service from the telco, a CID card in your Pana system (TA82493, TA62493, etc.) and some programming. The Installation manual and Programming manuals have the procedure for installing and programming the phone system.
Carl
Sep 22, 2011 | Panasonic KX-T7730 Corded Phone
The caller id is working but how to look back the last caller id number(or caller id log) on the KX-T7731, i am using it with the KX-TA824 system.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
Carl
Sep 08, 2011 | Panasonic KX-T7731 Corded Phone
Is the KX-T7731 caller ID equipped?
The CID comes from a card with a part number ending in 93 as in 62493, 82493, 84893, etc. That and programming will display CID to Panasonic system display phones.
Carl
Feb 22, 2011 | Panasonic KX-T7731 Corded Phone
I installed a caller id card in my kx-ta624 panasonic system in my home. The manual I have describes kx-t7030 phones with a caller id indication button but my phones kx-t7730 do not have a button and so I...
You get to program it :-)
In the User's manual section 2-2 there's an alpabetic index for Caller-ID. It requires 2 buttons, a CID-Indicator and a CID-Select button. We usually put them as the top 2 buttons in a 773x series phone, but you'll have to pick 2 adjacent or similar CO buttons. You label them CID-I and CID-S. Then you program them for either 96 and 97 or 6 and 7. You also have to tell the programming that you are setting up the common CID if you use 96&7.
Carl
Dec 12, 2010 | Panasonic KX-T7730 Corded Phone
How to active caller id for panasonic kx-t7730?
Caller-ID is a function of the phone SYSTEM and requires 3 things, CID service from the phone company, a CID card ending in 93, and programming. It works on TD, TA and higher models.
Carl
Nov 28, 2010 | Panasonic KX-T7730 Corded Phone
How do I get calls(caller id) to show up on LCD?
Panasonic systems require 3 things for CID, 1. CID service 2. CID hardware 3. System programming.
Once you get all 3 things, you'll have caller id. There is also some set programming to log and list calls that is found in the Operating Manual for your system.
Carl
Sep 03, 2010 | Panasonic KX-T7633 Corded Phone
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Cannot turn off audio caller ID
Try the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.PDF
On page 35 it lists how to turn off talking cid for both the handset (90) and base (0*40).
Carl
Feb 28, 2009 | Panasonic KX-TG5672 Twin Cordless Phone
Panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Dec 05, 2008 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
