Question about Nutrifaster Ruby 2000 Juicer
Base motor motor hums and does not start. it starts only if you spin the chaft.
    Problem Solver:
  • 14 Answers
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Posted on Aug 01, 2013
The moment it is switched on& a small quantity of vegetables r put in the machine starts vibrating & in another minute starts spinning out of control,it's difficult to hold it down with both...
It is quite possible that the motor bushes , bearings or the jar bushes are worn out as this will make the motion of the high speed motor to allow the friction to work through therby making the whole assembly to vibrate.
You need to check this by observing the shaft play, it will be very minute but is enough to cause problems.
Aug 08, 2011 | Omega Juicers
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
I can't clean my juicer
If you have a dishwasher, all parts except the motorized base are top rack safe. If you don't, fill the sink with hot soapy and let sit until loosened and wipe clean. The motorized base gets wiped with a damp sponge and dried. If there is more about the situation than you have mentioned, please let us know and we will help in every way we can.
Best regards,
farmerbear at FixYa.com
Sep 12, 2010 | Jack Lalanne Power Juicer 250 Watts
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
My Acme supreme juicerator #6001 trips off several times before I can complete the process of juicing in order to get an 8oz. glass of juice. The motor spins smoothly, no vibration at all.
There is a reset button on the bottom of the
juicer. You will have to separate the base
by removing the 4 bottom screws and adjust
the sensitivity of the reset button turning the
small screw on it. Sorry, but forgot which
direction increases or decreases this. Had
to do it on my 21 year old Acme because of
the same problem.
Apr 22, 2010 | Acme 6001 Juice Extractor
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Nutrifaster Ruby 2000 Juicer Logo
112 people viewed this question
Top Nutrifaster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
