Question about Cell Phones
Home button in iphone dos'nt work
I have a probleme in my home button iphone 4
    New Friend:
I have a way to bypass on using the home button. It is a way to create a home bottom that becomes a touch screen setting. How you get to it is through setting. First it is under general.... Go down to accessibility .... Then you will see an assistive touch option. Turn it on and there you go.
Hope this helps till u find a permanent way to fix it.
Posted on Jul 13, 2013
  • bebatoou Jul 13, 2013
    Thnx thnx that's work
  • Rene Leontiadis Aug 29, 2013
    Also you can fix your home button just by cleaning it.Take the white spirit and put a bit arround the button and push it 10 times.It should work
Iphone 4 home button does not always work.
I think your device should be sent to repair. That issue may get worsen by the time. It's probably a hardware fault on the home button and "made in home" tools won't work for that unless you're an expert on repairing mobiles. Send it to repair
Jun 08, 2017 | Apple iPhone 4 Black Smartphone
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
I dnt knw its nt starting it just show apple symbol n its nt getting switch off also nt even charging
I would first try doing a soft reset by pushing and holding both the power button and the home button at the same time, continue holding until the apple logo reappears, then wait to see if it boots up. If that doesn't work, try doing a restore by plugging into PC and clicking on restore in iTunes on your PC. If this doesn't resolve your problem, call 1-800-MYIPHONE to set up an appointment in an Apple store so a tech can repair your device. Hope this helps!
Apr 26, 2011 | Apple iPhone 3G
I can't find sync in itunes ,can't sync iphone
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 28, 2009 | Apple iPhone Smartphone
Iphone hangs during standby mode.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 26, 2009 | Apple iPhone Smartphone
I keep trying to sync my iphone to itunes, but it keeps saying an unknown error(13019)? What do I do?
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 06, 2009 | Apple iPhone 3G
I have factory unlock iphone 3g my problem is when i charging
try these resets:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 27, 2009 | Apple iPhone Smartphone
Same problems
Try these resets:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 23, 2009 | Apple iPhone 3G
My iphone is frozen after i restored it how can i solve this problem
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
Jun 15, 2009 | Apple iPhone Smartphone
My iphone won"t turn on
you should be able to reset it by keeping pressed the top button and the home button for more than 10 seconds when it si connected to you computer. let me know if it works!
Apr 08, 2008 | Apple iPhone Smartphone
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
